HTTP 522 timeout - HD Audio component
cattboy
8 (0.01/day)
.nvc/MSVCRT.nvz.001 error when checking additional component HD Audio via HDMI
  • Using "Install best driver" and leaving all components unchecked, works fine.
Trial and error of optional components using "Best driver" 560.81-desktop-win10-win11-64bit
  • Checking only PhysX - Success
  • Checking only HDAudio - Success
  • Checking PhysX, HDAudio, MSVC2017 - failed error SS below
Deleted the TEMP\NVCleanInstall, no luck
Event Viewer has no logs/errors, no luck
Waited and clicked Retry, a few times, no luck
OS: Windows 11 Pro N v23H2 build 22631.3958
Looking in the temp path, HD Audio is in there? Feature complete? Not sure
On the other hand, it doesn't allow me to go from the first one. Does anyone know how to solve it? I'm on the same version of OS WIN 11 23H2 as you.
