I am alive "Errors on some hardware" gtx 680 won't run it.
3,994 (0.60/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
EDIT: FOUND FIX.
http://forums.steampowered.com/forums/showpost.php?p=32905831&postcount=5
I bought this game last night thinking it looked cool. It's been nothing but a headache so far.. I'm reading the controls are messed for one. But that's not even a concern to me yet, as I can't even play the dam game..
Just gives me an error code stating my 680 gtx is not supported, then stops installing.. This is what I have come to expect from ubisoft..
First time I've ever asked steam for a refund. Pathetic to release a game that is as buggy as this though..
I know I used to use some other digital distributor before.. Hmm..
Guess I'm going to have to go find them and hope they don't start ruining their system as well.
Steam has been getting worse and worse lately..
EDIT: Found a fix.
1. Go to this location on your hard drive.
If you have a 64 bit windows system go here.
C:\Program Files (x86)\Steam\steamapps\common\I am Alive\src\SYSTEM
If you have a 32 bit windows system go here instead.
C:\Program Files\Steam\steamapps\common\I am Alive\src\SYSTEM
2. Open UserSettings.ini in notepad and change
RunValidation=True
to
RunValidation=False
and save and close the settings.
I wanted to get this game, looks pretty interesting. Hopefully if I get it, I won't have the same issues. Maybe I'll wait a while for further patches
Wasn't even aware it was available on PC. I do however recall the graphics looking a lot worse than the trailers indicated as far as the console versions. Not sure if the PC version looks bad too, but I can't help but be skeptical. I also recall the gameplay was said to not be nearly as good as they'd made it sound like it would be. The Last of Us I'm sure will be much better, but probably no PC version.
well morphological filtering was the only way i could get this game to aa without giving the main charachter a white outline to his hair... completed in just over 3.30hrs...
its a puzzle game... not bad.... just not good iether...
I decided to try it since it can be had for only $15. Great concept, poorly executed. Some of the nav puzzles are engaging, but the aim, movement and combat are extremely console clumsy, the map segments reused too much, the graphics terrible, and the story wastes a lot of potential. The AI is not bad for a budget game, but that and some of the route finding are the only bright spots.
Oddly enough the concept alone left me hungry for more. I really hope The Last of Us comes to PC eventually. BTW, purecain, what did you think of the last heavy armor guy? Seemed intimidating at first, until I discovered how easy it was to take him out, then I had to laugh.
lol yeah, if your on about the last scene in the amusement park...
he got an arrow to the balls... (should of gone for the knee) lol
Climbing down ladders can get annoying and the game is pretty much colorless the whole time oh and a bit repetitive . Other than that not bad. Don't really feel like finishing it though, not atm.
Yeah that's the part, the one that brags about his riot gear. I hit him closer to the knee actually, femur anyway. I gotta say, at least the game recognizes that as a critical hit point, like most games should, but few do.
