I can't access my NAS share drive anymore if I remotely connect to my home LAN via openvpn
64 (0.40/day)
System Name My Main Machine
Processor i7 7700K @5.1 GHz
Motherboard ASUS Maximus extreme IX formula
Cooling XSPX Raystorm Extreme Water Cooling Kit
Memory 64 GB of Ripjaws RAM
Video Card(s) MSI GeForce RTX 2080 Ti
Storage Two 512 GB samsung 960 pro in RAID 0 configuration for OS
Display(s) LG 34" 34UC98-W Curved Monitor
Case Thermaltake core X9 case
Power Supply Seasonic PRIME 850 Watts PSU
Hi to all,
I have the ASUS RT-AX88U router. I use openvpn to vpn into my home network from anywhere. I can do it from my iphone and also my laptop. When I first configured it for my laptop, I mapped my NAS share and it was added as a network drive and worked perfectly. After sometime, it won't connect if I use my laptop to access my home network remotely. I mean, the laptop will be as if it is a local machine in my home network, but I won't be able to access the NAS share drive. I can ping my NAS, and I can also access its GUI and navigate files from there but I can't access the share drive from file explorer which is weird. If I remove the drive and try to map it again, it won't work also. Of course, If I connect my laptop to my LAN normally via WiFi when I'm at home it will work. What gives?
