I have an issue with my predator 15, games load as black screens, can only get to display by changing resolution. PLEASE HELP
stevemaddenku
4 (0.00/day)
Hi i currently have some horrible display issues with my predator 15
Processor
Intel Core i7-6700HQ (Intel Core i7)
Graphics adapter
NVIDIA GeForce GTX 980M - 4096 MB, Core: 1038 MHz, Memory: 2500 MHz, GDDR5, ForceWare 354.00, Optimus
Memory
16384 MB
, 2x 8 GB DDR4-RAM (2133 MHz), 2 of 4 slots filled, max. 64 GB
Display
15.6 inch 16:9, 1920 x 1080 pixel, LG LP156WF6-SPP1 (LGD04D5), IPS, Full HD, glossy: no
Mainboard
Intel Sunrise Point HM170
Storage
Lite-On CV1-8B256, 256 GB
, M.2-SSD + Western Digital Blue WDC WD10JPVX-22JC3T0, 1000 GB HDD @5400 rpm
Basically the laptop crashed (blue screened) and ever since ive been having trouble loading any of my games and some programs.
The games will load but will not display. The games audio will play as normal and i can see the processes running in task manager. I've tried updating my graphics drivers and a bunch of other random fixes but to very little success. The only workaround I've accomplished is changing my resolution from 1920x1080 to a lower setting and then my games will display and run fine. Some games will run at my normal resolution. I'm completely lost and hoping someone can help me figure out whats wrong. Using my laptop at a garbage resolution is just impractical and just a pain to do!
Sometimes instead of black screens i also get no display at all!
14,546 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Can you post a screen shot of the Blue Screen error message?
It will help us to determine what is wrong.
stevemaddenku
4 (0.00/day)
I actually dont know if i can as it happened weeks ago. Unless there is some way to access the record of it maybe saved somewhere.
I think in im the right place but not certain. I also believe this is the right date where the initial issues started\
maybe this?
1,487 (0.31/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
have you cleaned the fan vents lately on your machine? Latest drivers? What do the "errors" say when you click on them?
stevemaddenku
4 (0.00/day)
I have not cleaned the fan vents lately, heres some screenshots of what the error says when i click them
The second 2 screen shots are the errors i get when i try to load a game. I did update the drivers for my graphics card.
14,546 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Try to rule out heat first by checking the fan is working and vents clear etc, also use monitoring software like HWMonitor to check temps.
1,487 (0.31/day)
Anchorage Alaska
Thanks @Caring1 I was going that direction :)
stevemaddenku
4 (0.00/day)
The computer has a built in fan cleaner acer dust defender which i used and the computer doesn't really show any overheating on HWMonitor temperature seems normal even when running some demanding games that still work on my PC like fallout 4. I do also believe the computer did overheat at the time to cause the crash im just not sure how to repair any damage it may have caused to whatever i need to display certain programs in higher resolution.
Edit - Im pretty dumb i think the issue may be that i only updated my 980m drivers but not the Intel HD 530 drivers trying that now
1,487 (0.31/day)
Anchorage Alaska
I would not rely on the dust defender. I would flip it over and visually inspect it and use some canned air to blow thru the vents. Maybe re-paste the gpu/cpu.
44,274 (6.80/day)
Yup, dust your vents and fans, download last known working gpu driver, latest chipset drivers, disable/turn off wifi or disconnect ethernet, ddu your gpu drivers twice restart each time. Install latest chipset driver, restart, then install last known working gpu driver, restart. Make sure windows power properties are set to max performance.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I also have an Acer Predator 15, similar specs. I had the black screen issue for a couple of games (Gal Civ 3 and BSG Deadlock). I tried a myriad of solutions, even re-installing the OS. The one that did the trick?
Uninstalling the Intel GPU, check the box to remove the drivers, reboot. Install the latest Intel-Official GPU drivers. Otherwise the only resolution that would display those games was 1280x1024 UNLESS I was forcing the Intel GPU...then 1920x1080 was fine, but performance was horrid.
44,274 (6.80/day)
Intel strikes again, i knew on desktops igps could cause resource conflicts...
23,872 (6.16/day)
Kernel-Processor Power points to voltage problems / power supply problems either due to excessive temps+OC (ie dust etc.) or perhaps your power brick doesn't provide enough juice. This can happen over time as caps degrade.
I think your software and address errors are just a logical result of that; the CPU starts throwing errors.
One possibly very easy test is trying a replacement power brick to see if issues go away. Its also one of the easiest components to replace.
And cleaning, but that is standard procedure IMO
