I need a new power supply and i need some help.
222 (0.04/day)
Argentina, Latin America
System Name CRIMSON TYPHOON
Processor Corei5 6600k Skylake @4.2ghz (COOLED BY A COOLERMASTER HYPER 212)
Motherboard GIGABYTE Z170XP-SLI
Memory 2x8GB CORSAIR VENGEANCE RED LED DDR4 3200MHZ
Video Card(s) ASUS 1060 OC6GB @1950mhz
Storage Western Digital Caviar Blue 1TB 64MB Cache
Display(s) LG 24'
Case COOLERMASTER CM STORM ENFORCER
Audio Device(s) OnBoard Realtek HD
Power Supply Thermaltake SMART M Series SP-650M
Mouse Razer DeathAdder Chroma
Keyboard Corsair K-70 (Cherry MX Red Switches)
Software Windows 10 x64 Ultimate Edition
Hi guys like the title says, i need some help, in my system specs you can check out my current rig. I must replace my PSU since it's at it's absolute limit, as a matter of fact it's starting to act up regarding the voltages it's giving to some of my components.
That being said, here's the full list of PSU's i can get, the pricing it's 10 pesos = 1 dolar more or less.
Let me know what's better for me in a bang kind of way.
I would like a PSU that could hold my setup and gave me a little bit of wiggle room for something else. FYI I am not into Xfire nor SLi, so don't worry about that, i mean a processor change, or maybe a VGA change someday.
Powercooler PS-630MAX 630W $ 1.308
TOPOWER 600W ATX 12V 2.3 TOP-500W $ 1.165
TOPOWER 650W ATX 12V 2.3 TOP-500W $ 1.263
TOPOWER 700W ATX 12V 2.3 TOP-500W $ 1.588
NZXT HALE82-N 550W 80 PLUS BRONZE $ 1.398
NZXT HALE82 HALE82-650-M 650W 80 PLUS BRONZE $ 1.895
SENTEY BRP700 700W $ 1.229
SENTEY Essential Plus Power EPP650-PS 650W 80 Plus Bronze $ 1.353
SENTEY Essential Plus Power EPP750-PS 750W 80 Plus Bronze $ 1.579
SENTEY Extreme Rock Power ERP650-PS 650W $ 1.128
SENTEY Extreme Rock Power ERP750-PS 750W $ 1.371
SENTEY Solid Core Power SCP650-HS 650W 80 Plus $ 1.542
SENTEY X PLUS POWER XPP625-PS 625W $ 1.102
COOLER MASTER Extreme 2 RS-725-PCAR-D3 725W $ 1.823
COOLER MASTER GX 650W 80 Plus $ 2.064
COOLER MASTER GX II 650W 80 Plus Bronze $ 2.208
COOLER MASTER GX II 750W 80 Plus Bronze $ 2.595
COOLER MASTER I700 700W 80 Plus Bronze $ 1.984
COOLER MASTER Silent Pro M2 620W 80 PLUS BRONZE- Full Modular $ 2.526
Thermaltake TR2 TR-500 500W ATX12V v2.3 $ 880
Thermaltake TR2 TR-600 600W ATX12V v2.3 $ 1.056
THANKS A LOT IN ADVANCE GUYS!!!
739 (0.17/day)
Kolkata, India
System Name barely hangin on...
Processor Intel I5 4670K @stock
Motherboard Asus H81m-cs (nothing else available now)
Cooling CM Hyper 212X (in push-pull)
Memory 16GB Corsair Vengeance Dual Channel 1866MHz
Video Card(s) Asus RX 580 4GB Dual
Storage WD Blue 1TB, WD Black 2TB, Samsung 850 Evo 250GB
Display(s) Acer KG241QP 144Hz
Case Cooler Master CM 690 III (Transparent side panel) - illuminated with NZXT HUE RGB
Audio Device(s) FiiO E10K>Boom 3D>ATH M50/Samson SR850/HD599SE
Power Supply Corsair RM 850
Mouse Redragon M901 PERDITION 16400 DPI Laser Gaming Mouse
Keyboard HyperX Alloy FPS Mechanical Gaming Keyboard (Cherry MX Brown)
Software 7-64bit MBR, 10-64bit UEFI (Not Multi-boot), VBox guests...
Get at least a 80+ bronze certified Seasonic or Corsair. Get a modular one for better cable management and better airflow. You may take a look at the new Corsair RM series PSUs. Those are 80+ Gold certified and have flat, modular cables are are darn cheap.
222 (0.04/day)
Display(s) LG 24'
This list contains the PSUs i can purchase from my supplier, this is why i posted it, i sincerely don't need sugestions outside of this list. I mean there must be at least one in the list that is actually good right? Thanks!
12,062 (2.53/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
On that list? I'd go for the NZXT Hale. But Sea Sonic or Enermax OEM PSU's are advisable. I'm sure there are more than one supplier where you're from.
550W Bronze rated is enough.
222 (0.04/day)
Display(s) LG 24'
I see, of all of the PSUs listed here this one ( COOLER MASTER I700 700W 80 Plus Bronze $ 1.984 ) has the best reviews all around, isn't CoolerMaster a good brand anymore?
Thanks for the help guys.
(About my supplier, there are other suppliers yeah, but this one it's a friend, i have ease of payment and other perks)
UPDATE: Going a little outside of my comfort zone i found these 2 for a good price, so i'll add them to the list:
http://articulo.mercadolibre.com.ar...-bronze-80plus-620-watts-reales-m12ii-620-_JM
http://articulo.mercadolibre.com.ar...maltake-smart-650w-pcie-x-2-80plus-bronze-_JM
739 (0.17/day)
Kolkata, India
I have not used any of the ones you listed, so I cannot recommend any of those. But, as I said, any good 80+ Bronze (I missed the word "particularly" when I said Seasonic or Corsair) is good-enough. Cooler Master is renowned for quality - amongst the names you listed. If you must choose from the list then CM would probably be the way to go, then NZXT maybe, but I'm not sure about NZXT's components/quality etc.
If the supplier is your friend, then ask him to get you a Seasonic or an RM-series Corsair (these are the only ones I have used, and can thoroughly recommend. Also, Enermax's own models are good too), or look elsewhere. No reason to make a bad investment on the most important part (which can screw up every other pc component) just for perky perks.
Good luck!
Edit:
After seeing your edit I thought I'd recommend the Seasonic M12II. But do check if it's "full" or "semi modular". There are both in the M12II range.
222 (0.04/day)
Display(s) LG 24'
Good luck!
Yeah i see your point, i listed a Seasonic and a Thermaltake somewhere down the road, what do you think about those?
739 (0.17/day)
Kolkata, India
See "edit" above.
6,871 (1.09/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
my recommendation is for either the Seasonic you added or one of the NZXT HALE 82 units.
222 (0.04/day)
Display(s) LG 24'
For the price tag, i'm really diggin' the HALE82 modular 650w, it's really cheap and the reviews so far are great...
836 (0.12/day)
Romania
System Name Rocket
Processor Ryzen 3600X
Motherboard ASRock B450 PRO4
Memory HyperX Predator Black 16GB DDR4 3200MHz CL16
Video Card(s) MSI GeForce GTX 1060 GAMING X 6GB
Storage ADATA SX8200 PRO 512GB + Intel 535 Series 120GB + WD 6400AAKS
Display(s) Benq EW2420
Case Antec P182
Power Supply Antec Signature 650
Software Win 10
NZXT HALE82-650-M. It's a Seasonic inside. :)
82 (0.02/day)
Oshawa, Canada
System Name Old but Good.
Processor Intel Core i5 2500K at 4.8GHz (1.425)
Motherboard Asus P8Z68-V\GEN3 BIOS 3402
Cooling Cooler Master EVO +212, 4 120mm case fans.
Memory 4x4GB Kingston ValueRam DDR3-1333/1600 at 1600, 1.6v
Video Card(s) 2 eVGA GTX 760 2GB at 1214/7800 ACX SLI
Storage 2TB, 3TB SG Barracuda SATA 6 and a SG Expansion 3TB USB 3.0 drive
Display(s) 27" Acer G276HL LED Monitor 1920x1080@66Htz
Case Cooler Master
Audio Device(s) Realtek on-board 5.1 Surround
Power Supply 750w Cooler Master GXII SLI/XFire-ready
Mouse Logitech G500 Gamin' Mouse (8 Buttons)
Keyboard Mad Catz S.T.R.I.K.E.R. 3
Software Windows 10 Pro Build 10565
Benchmark Scores 3DMark2006-77891 3DMark Vantage: 64,558
I have a PS on your list. It's a CoolerMaster GXII 750w. It's powring 2 GTX 760 2GB at 1214/7600, an i5 2500K at 4.5GHz and 8GB of Kingston ValueRam 1333 at 1600. As you can see my system is heavily overclocked. Hell, even my monitor is overclocked (67Htz). I've had this PS for 3 years and it's serving me very well. I highly recommend it.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I've had great luck with COOLER MASTER Silent Pro M2 620W 80 PLUS BRONZE- Full Modular. The GXII750W would be a great choice too.
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Just avoid the Thermaltakes, they are crap.
222 (0.04/day)
Display(s) LG 24'
Thank you for all of your replies guys.
