- Apr 11, 2025
- 5 (0.11/day)
System Name | Urack |
Processor | Ryzen 7 9800X3D |
Motherboard | Asus TUF X870p-Plus WIFI |
Cooling | Deepcool AK620 Digital PRO |
Memory | T-Force DELTA RGB DDR5 32gb 7200Mhz |
Video Card(s) | Asus ROG Strix 5080 |
Storage | SK Hynix Platinum P41 PCIe NVMe M.2 2tb |
Display(s) | Samsung Odyssey G4 27" 240Hz |
Case | Corsair 4000D Airflow |
Audio Device(s) | Logitech G PRO X Lightspeed Shroud Edition |
Power Supply | Gigabyte UD1000GM |
Mouse | Logitech G903 Lightspeed |
Keyboard | Logitech G915 TKL Lightspeed |
Software | Windows 11 Pro |
It's an RX 580, clearly an SP2048. It has no brand and nothing that would indicate which brand it could be. I've tried many vBIOS versions and managed to find a few that work correctly, giving me acceptable performance for the type of GPU it is.
The problem is that I can't increase my monitor's refresh rate with these BIOS versions — I'm only allowed to use 60Hz at 1920x1080p. When I try to increase the Hz, the resolution drops. The higher the refresh rate, the lower the resolution. I'm using HDMI 2.1, and DisplayPort doesn't work.
I've attached a GPU-Z screenshot. I don’t know what else to try, but I have access to practically all the relevant information needed to find the correct BIOS — I just can’t seem to identify it in any way. Please help!
