I need to replace my Antec 3-fan, but with which fan?
649 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
you supreme overlords of pc... can you please help me with 1 matter? below, you see my 2 fans. the fan to the left (antec 3) belongs to the fan on TOP of my pc, which is the one i want to replace wit a new fan, but i don't know it's dimensions, unfortunately. and as you can see, one its blades = broken, which again is causing my pc to be rather shaky...
the 2nd fan, is a Noctua NF-S12A PWM 120mm. and as you can see on the 2nd photo, the Noctua-fan (marked with 1 on the photo), has a smaller 4-pin power cable than the Antec 3 (marked 2 on the photo). the smaller 4-pin power cable does not fit to my pc (because it's old).
sooo basically, i need to find 1) a bigger fan than the Noctua (which is 120mm) so it matches the Antec 3-fan dimensions and 2) a fan that has the same power cable as my Antec 3 does (or can i use an adapter?)
other requirements:
- the fan should have speed adjustment options (i.e low/hi)
- a budget fan (costing somewhat $10-30)
- obviously, i need it to be quiet
- IMPORTANT: NON-FLASHY! i dislike if the fan is too bright/making colors etc. so that's not cool...
so. WHICH fan should i go for that matches those (picky) requirements? any suggestions?
also, if you cannot give me a specific fan-suggestion, can you at least tell me what i should be looking for when it comes to dimensions (so it matches the dimensions of the antec 3-fan) AND the power cable? what sort of power cable is it? (pardon my noobness...)
thanks in advance once again, my overlords!
f32ddf0a-fd6c-4d73-a34a-d48be1ed2e8e.jpg 652b4d6f-d266-4eee-bbf1-884b1fe1bb0e.jpg
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Big fan is a 200 mm, antec still makes them. You can use any 120 mm for the front, I used a 10 buck thermaltake on mine. Same 4 blue leds ect. Use your mobo's pwm controller to adjust fan speed. You can also get 120 mm antec fans still with the tri-switch. I own an old antec case, so I've had to start hunting for new fans too. If you want to make it simple, just replace with the same antec fans, otherwise any 200 and 120mm fans will do.
14,557 (3.79/day)
Sunshine Coast Australia
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
140mm fan, not 200
The small four pin PWM connector should still attach to the three pin header on your motherboard, you just lose the PWM function.
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Measure it and find out. As johnspack suggested it could be a 200mm but looking at your photo, it looks more like a 140mm to me too since 20mm is just over 3/4 inch longer than 120mm. 60mm more would be over 2.25 inches wider.
Case fans are measured from outside edge of the fan housing to the opposite outside edge (from the flat side to the other flat side with this Big Boy).
Replacement Antec "Big Boy" 200mm are ~$20 on Amazon. It should be noted that Antec makes excellent fans (if you keep your knuckles out of the spinning blades), but certainly you don't have to buy Antec.
649 (0.11/day)
ok, i did some measuring, and if i've done it right, it says 140mm... this is correct, right?
so, i then need a 140mm-fan, huh?
and about the pin.. well, i do have one old pc, so i dont know if i really have that on my pc or not.. hm... my motherboard = gigabyte ga-ma790x - and i cannot spot anywhere where that 4-pin cable would fit....
also, i cannot attach the 120mm noctua fan where the antec 3 fan is located on, right? it's simply too small...
thanks again.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
You didn't do it right. Don't measure case vent openings. You need to measure the fan itself. It looks like it is 140mm but measure the fan or your mounting holes may not line up.
649 (0.11/day)
what about now then? did i do it right this time, or? (yes, the numbers are in 'cm')
i guess we can state that the big Antec 3-fan i've got on the top of my "tower" is a 140mm-fan..
if it's a 140mm, i got a refund option available from the store... which of these 140mm fans would be best, based on my above-mentioned requirements:
- Noctua NF-A14 PWM 140mm
- Noctua NF-A14 FLX 140mm (connector difference from the PWM?)
or any other suggestions that will fit my motherboard?
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Yeah, that's 140mm.
As far as which would be better, that depends on what you are looking for. It looks like the PWM moves more air so that would be better for cooling while the FLX still moves a lot of air, it is quieter. I like quiet - but only if I have sufficient cooling.
649 (0.11/day)
thanks a lot for your inputs, bill! that certainly made my decision very easy. i like quiet too. but, what about the power cables and all? will either of the noctua PWM or FLX fit on my motherboard, you reckon?
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
There is a 4 pin near the bottom corner labeled sys_fan. You would need a long enough cable for that to reach.
14,557 (3.79/day)
Memory 32 GB DDR4
Mouse Lenovo
It will also connect to the three pin header on the motherboard, near the yellow USB connectors.
809 (0.12/day)
Tampa FL
Processor AMD Ryzen 3800x
Motherboard Asus TUF Gaming X-570-Plus (WiFi)
Cooling Corsair Hydro Series H110i
Memory 32 GB Corsair Dominator RGB DDR4 3200 Mhz @3600
Video Card(s) Asus AREZ RX Vega 64 Strix OC 8GB
Storage Samsung 970 EVO Plus 1 TB
Display(s) Asus PB258Q 25" 2560x1440
Case Cooler Master Master Case 5 Pro
Power Supply Corsair RMx 1000
Software Windows 10 Pro 64
649 (0.11/day)
I found out that my CPU_FAN slot (on the far right side of the above photo of the motherboard) is not in use.. can i plug the fan there, perhaps?
Also, seeing that i need a new fan with a BIG 4-pin cable and not the small 4-pin cable, what is the name of those kind of cables??
Thanks for the suggestions.
14,557 (3.79/day)
Memory 32 GB DDR4
Mouse Lenovo
Yes you can plug the fan to the CPU fan header.
The large four pin connector is called a Molex connection, you may need an adapter as most fans have the small connections.
649 (0.11/day)
Thanks for the quick reply!
Ok here is my setup now. I connected the fan to that cpu_fan-slot. But is the fan mounted correctly in terms of airflow, or? It seems right to me, but i just wanna be sure on that.
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Other way. It should be exhaust
649 (0.11/day)
Ohh.. i see. Was trying to follow this guys setup:
So i just flip the noctua fan the other way then?
INSTG8R
8,150 (1.09/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
649 (0.11/day)
Nice. That seemed to do the trick as they are all working like a charm now.
Now, i just need to find the proper replacement 140mm for the antec 3 fan..
You guys... best pc help forums i have ever been a member of! Aweesome stuff!
809 (0.12/day)
Tampa FL
14,557 (3.79/day)
Memory 32 GB DDR4
Mouse Lenovo
Actually that rear fan isn't even required unless he changes the direction of the CPU cooler 90 degrees to exhaust out the rear.
That Noctua fan would be better placed on the front or bottom of the case to increase flow through the case.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
The best way to remember is you generally want front-to-back flow through the case. So front fans intake and rear fans exhaust. The reason you want front-to-back is only because power supplies mount to the back of cases and exhaust their heat out the back. So to keep the air flowing in the same direction, you orient case fans for front-to-back too.
If you have bottom and/or top "blowhole" fans, you want to "work with nature" and help the heat rise out the top. So bottom fans should intake and top fans exhaust.
For heatsinks with fans that don't blow sideways, you want the fan to blow onto the heatsink as that directs the most force on the heatsink and creates the most turbulence across the heatsink (a good thing).
Note many, if not most fans are labeled or have molded in the plastic housing, two arrows. One arrow designates the direction of air flow, and the other the direction of fan rotation.
809 (0.12/day)
Tampa FL
A couple things: First, rotate your heatsink 90 degrees so the fans face front to back on it.
Second the easiest way to find out the airflow direction of a fan is to simply look at the curve of the blades, the direction the air flows in will be the inside of the curve of the blades.
649 (0.11/day)
Ok so..
1: heatsink/cooler - is that the silver metal thing (with a fan attached to it)? If so, is it this what you want me to turn 90 degrees so it faces the top fan?
2: yes, i currently have only 3 fans, as you can see on the photo above. Also, the gpu too has a fan, of course. Im not sure if Antec 300 lets you have a fan in front... it is a rather small/narrow cabinet... hmm...
3: i landed on a 140mm noctua fan to replace the top fan with the broken blade. But now i have one spare 120mm antec fan. Should i mount that one anywhere, or will these 3 fans do it?
4: wait.. the rear fan is now the previously mentioned 120mm noctua fan, but since i was told that i had to turn the fan the other way around (unlike in the photo), did i do it correctly, or?
809 (0.12/day)
Tampa FL
Ok so..
1. Yes it's the silver/metal thing, However I didn't realize the case has a top exhaust fan, the position it's in now will work fine.
2 and 3: The Antec 300 can fit a 120 mm fan in the front bays in front of the hard drives etc. as intakes.
4: If you changed it from the way it was in post 15 then you're fine.
Bill, his particular case, the Antec 300 has a bottom mounted PSU and exhaust fand on the top and back. It's basically a budget slightly smaller version of the Classic Antec 900, his heatsink will work in either direction, though he might get more airflow over the memory and VRMs with a front top back config. But the HSF looks like a Hyper 212 which requires removing the motherboard and unscrewing the Backplate, etc. to changethe direction of the heatsink. He should be fine as long as he has both the rear and top fans set as exhausts.
