I/O Device Error
ex_reven
5,217 (0.76/day)
Hey guys, i just put together a new case and upon trying to use a cd I found that i got an error:
"The request could not be performed because of an I/O device error"
I have a 250gb SATA II drive connected to the mobo by means of a SATA cable.
While my LG DVD Drive is connected to the mobo with an IDE Cable, the IDE cable has 3 ends (one to plug into the mobo, one for an IDE Hard drive and another for a CD Drive i presume)
Is the error being caused because both the hard drive and the DVD drive think they are the primary devices? If so how do i fix this?
Thanks :toast: ,
Ex_ReVeN
Thanks :toast: ,
Ex_ReVeN
First off: Can you see this diskdrive in EXPLORER.EXE?
Secondly: Does this device say it is 'working properly', in the HDD sections of devmgmt.msc (run it from Start -> Run, & see)...
* Thanks, because it matters to an extent, on those parts... imo @ least!
APK
:wtf:
I just rebooted the computer, after having removed the power cables etc to check if i could see a slave/master jumper switch and the drive started working perfectly :ohwell:
Thanks for your considerations Alecstar, if I encounter more problems I shall repost ;)
and good luck with your "superchargers vs turbochargers" discussion
:wtf:
LOL! Good job... sometimes, reboots ARE all a body needs!
You're welcome!
LOL, thanks... it's as bad discussing THAT topic, as it is pagefile.sys placements & sizings, OR "chicken or the egg"...
APK
