- Jul 15, 2022
- 1,000 (0.98/day)
I tested both Speedtest.net and nperf.com and compared the results. nPerf gets slightly higher download results, the upload speed is the same, but with latency I saw a significant difference. Then I looked up which one is the more reliable of the two and I found the following topics:
original French text: Notre site de référence est nPerf, et je conseille d'utiliser toujours le même serveur (choix manuel) Wingo en Suisse 100Gbs. nPerf utilise plusieurs connexions simultanées pour son test.
Speedtest d'Ookla est pour moi moins qualitatif et souvent l'upload est bloqué chez moi.
Translation: Our reference site is nPerf, and I advise to always use the same server (manual choice) Wingo in Switzerland 100Gbs. nPerf uses multiple simultaneous connections for its test.
Ookla's Speedtest is less qualitative for me and the upload is often blocked for me.
original French text: Depuis 3 mois, je suis fibré (voir ma signature) , j'ai un forfait Orange 400Mb/s symétrique (en down et up ); avec Nperf, j'ai toujours autour de 400 dans les 2 sens et même des fois un peu plus! , mais avec Speedtest je n'ai jamais dépassé 300, souvent même en dessous de 200 ! mesures faites au mêmes instants ! j'ai même eu des valeurs très faibles inférieures a 10 alors que c'était faux.
Translation: For 3 months, I have been on fiber (see my signature), I have a symmetrical Orange 400Mb/s package (down and up); with Nperf, I always have around 400 in both directions and even sometimes a little more! , but with Speedtest I never exceeded 300, often even below 200! measurements taken at the same time! I even had very low values below 10 when it was wrong.
There are other topics that also report that there may be a difference between the two websites:
https://www.reddit.com/r/HomeNetworking/comments/6d17z5/_/dhz1upk Speedtest.net seems the most fishy/infiltrated by ISPs.
For this reason I'm going to post my nPerf result:
[RESOLU] nperf vs speedtest, pourquoi ces différences énormes ?
Bonjour, Je n'ai pas trouvé de réponse sur le site (en tout cas je ne l'ai pas vues), donc merci pour votre tolérance à mon premier message ;)
routeur4g.fr
speedtest.mybroadband vs nperf.com
If I run a speedtest using http://speedtest.mybroadband.co.za/ I get: Ping 3ms Download 194 mbps If I run a speedtest using https://www.nperf.com/en/ I get: Ping 16ms Download 625 mbps Both sites showed similar upload speeds, around 95 mbps. nperf reports more than 5 times worse latency...
mybroadband.co.za
