i7 upgrade from i5?
1,299 (0.23/day)
Ohio
System Name Vegnagun
Processor Ryzen 5950x
Motherboard Asus B550 Gaming-E
Cooling Noctua NH-U14
Memory 4x8 G. Skill 3800mhz CL14
Video Card(s) EVGA RTX 3080 FTW3
Storage WD SN850 2tb
Display(s) Viotek 1080p 120hz
Case Fractal Design Define 7
Power Supply Corsair AX850
Mouse Logitech
Keyboard Logitech 815 tactile
Software Windows 10 Education
Benchmark Scores top 1% in the world for weekly score in Killzone 2 :)
Hey all,
Long time no posting. My wife is looking to use my PC for working from home. PC is 7ish years old running an i5-750. Her work is very CPU intensive, and I'm wondering your thoughts on me simply tracking down an 1156 i7 processor to change out, or if I should just build a new system over? So far, I've only looked on the egg and found one for $220ish.
My system specs are currently what I'm running.
Thanks!
3,505 (0.60/day)
What kind of application does she use?
Depending on how CPU depedent her work is HT from i7 would be well worth the extra.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
If you can get a used one on E bay for $30 and your board supports it then do it. But otherwise just use it as it is. i5 -750 is still decent
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Should be able to get an 860 for under 100. Otherwise don't bother..... And I've checked amazon, they can be had for under.
14,557 (3.79/day)
Sunshine Coast Australia
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Check out Xeon Processors if the board can use them and her work requires cpu intensive applications.
peche
Thermaltake fanboy
6,709 (1.75/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
i7 is goning to be a notable upgrade, xeon are too, it depends what you look for, with an i7 you will be more than pleased i know, i can bet that,
Regards,
dorsetknob
9,106 (1.24/day)
See if Mb supports Xeon X3480 then see if you can find one reasonably priced
# of Cores 4
# of Threads 8
Processor Base Frequency 3.06 GHz
Max Turbo Frequency 3.73 GHz
TDP 95 W
That is the Best you can get for 1156 Socket
I7 ver is
i7-880 Processor Same spec as X3480 ( xeon probably easier to find and cost less )
38 (0.01/day)
System Name desktop
Processor Ryzen 5600x
Motherboard Gigabyte B550M AORUS ELITE (rev 1.1)
Cooling Thermalright Phantom Spirit 120SE
Memory G.Skill Trident Z Black & White F4-3200C16-16GTZKW 2x16GB
Video Card(s) Radeon rx 6600
Storage 1x Samsung 980 pro 1TB (cpu nvme slot), 1x sata 860 evo 1TB, 1x sata 840 evo 500GB, 1x wd red 6tb
Display(s) Gigabyte M27Q (revision 1 aka one with the bgr subpixel layout)
Case GAMDIAS Athena M6 LITE Gaming PC Case
Audio Device(s) onboard sound on the motherboard
Power Supply random 10 year old 600W lc power supply
Mouse logitech g305
Keyboard logitech g413 carbon
VR HMD /
Software win 11 latest version
a xeon e3 v3 1235 costs about as much as an i5 and is an i7 - the gpu
should work in most boards that will take and i5/i7
it's haswell gen so there might be and even faster one with broadwell or sky lake tech
dorsetknob
9,106 (1.24/day)
You need to re read 1st post again
OP is looking to upgrade CPU on the1366 X58 platform 1156 P55 (edit)
Afraid your SO WRONG THERE
38 (0.01/day)
System Name desktop
Mouse logitech g305
VR HMD /
save some money and make that 4 cpu xeon beast :)
1,611 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
dorsetknob
9,106 (1.24/day)
My mistake :)
vision Bluring tired and Diabeties need to eat squirrel shit chocky Bar for glucose hit
( There is a hazel nut in every bite ):)
831 (0.26/day)
System Name Gaming Desktop
Processor i7 6700k
Motherboard asus rog alpha
Cooling H110i
Memory Corsair Dominator 16gb DDR4 3200
Video Card(s) GTX 1080
Storage EVO 840 500gb, EVO 850 500gb, Perc 710 Raid WD RED 4tbx4
Case Corsair 500r
Power Supply Antec 850
Mouse Logitec G502
Keyboard a cheap dell
Hey all,
Thanks!
there are other considerations as well. faster ram and sata 3 being large ones.
the cheapest route is a used x3480 as recommended above or an i7-880 . both are a little over $100 on ebay, that'll buy you hyperthreading and a small core clock boost ( 20-30% gain in cpu performance) . outside of that you may also be able to overclock your existing system and gain some additional speed.
given a choice between an i7-880 and an x3480 it really comes down to whichever you can find cheaper.
edit: more thoughts.
now the rest is going to depend on what app it is how & how well it threads.
for example for around $600 you can get an x99 board and a 12core xeon ( used) and a good amount of ram that will give you a 300% increase in raw cpu but doesn't perform as well in games or lightly threaded apps.
or you for ~$500 you move to the i7-6700k that'd probly be closer to double your current speed. but with much faster single core speeds which is better for gaming and lightly threaded apps.
Kanan
Tech Enthusiast & Gamer
3,517 (0.99/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Just go for the i7 if you get it really cheap 50 bucks maximum. Performance wise it's surely worth it, however.
