ide drivers not installing....
QuarterMain
46 (0.01/day)
CARLISLE,SOUTH CAROLINA
System Name WAITING ON AMD TO GET THERE S*** TOGETHER.....
Processor INTEL C2D 6750 2.6GHZ> @3.2GHZ
Motherboard MSI P6N-SLI PLATINUM
Cooling STOCK INTEL HS+FAN 1-120 INTAKE 2- 80MM XHAUST
Memory 2GB(2X1GB) PC6400/800MHZ 5-5-5-12 DUAL CHANNEL GSKILL
Video Card(s) XFX 7900GS 525m xtreme PCI-E (next on the list)
Storage WD 80gb sataI
Display(s) HANNS-G 19" WIDESCREEN LCD *JW197DBP
Case ANTEC-SILVER- P180 performance one case( and lovin it.....)
Audio Device(s) auzentech X-Mystique 7.1 GOLD
Power Supply Xnfinity 600w dual rail/flexforce R1/18A R2/20A
Software WINDOWS XP PRO SP2/ SLIPPD :)
hi guys,
a little prob, nothing major but i cant seem to get the nvidia ide drivers to install on my new mobo,(p6n-sli plat.) iv tried the newest ones from msi, and nvidia sites but none will install,itsfunny though cause the sata drivers all installed correctly.any ideas or suggestions on this would be appreciated,thanks in advance.
should i even repinn the optical drives if there running on an 80wire ribbon cable:confused:?im running to lite on opticals 1- cd\rw 1 dvd\rw. at present both are pinned to cs (cable select) and worked just dandy on my 939 board, i have no clue what the problem is with this new msi intel board:wtf:
The opticals can be on CS but not the IDE HDD"S. Put both HDD's on the same ribbon cable and both opticals on the same cable.
the only HD i have is sata and it was detected right off the bat, but its all a moot point now as iv gotten the ata drivers in now,its a shame when u have to dig thru the install disk files to find a file that should have installed with the initial chip drivers-- thanks for the assist
namslas90 it was much so much appreciated:D
