Increased VCore (Offset) vs Turbo Boost Voltage
VCore or Turbo Boost Voltage
  • Total voters
    9
85 (0.02/day)
Sydney, Australia
System Name Monster Gaming PC
Processor [Intel] Core i5 3570K
Motherboard [ASRock] Z77 Extreme4
Cooling [Cooler Master] Hyper 212 EVO
Memory [Corsair] 8 GB (2 X 4 GB) Vengeance Low Profile
Video Card(s) [ASUS] GTX 670 OC 2GB (GTX670-DC2OG-2GD5)
Storage [WD] Caviar Blue 1TB SATA III 7200RPM
Display(s) [Dell] UltraSharp 2407WFP (24" 1200x1920)
Case [CM Storm] Scout 2 Black
Power Supply [OCZ] ZT Series 750W
Software Windows 7 Ultimate,
While reading and following this guide I was just wondering which one can be considered better to increase to stabilize an OC. When I mean better, I mean in terms of power consumption while idle and effectiveness for the voltage.
85 (0.02/day)
Sydney, Australia
3,842 (0.86/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
never reallu used the offset voltages, i was too lazy to try and get it all stable. Whereas with the manual vcore i could set it and the multiplier and be done. I don't mind power consumption differences because i doubt its noticeable!
85 (0.02/day)
Sydney, Australia
I assume manual Vcore means fixed voltages? If so I think they have very similar effectiveness, only offset saves power on idle. In mean time, is offset better than turbo.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
You can't turbo volts......
Steady voltage is better for stability. ..
Offset is good for 24/7 high clocks with some economy ,im at 5ghz using 1- 1. 55 volts
548 (0.08/day)
System Name Ed-PC
Processor Intel i5-12600k
Motherboard Asus TUF Z690 PLUS Wifi D4
Cooling Noctua NH-14S
Memory Crucial Ballistix DDR4 C16@3600 16GB
Video Card(s) Nvidia MSI 970
Storage Samsung 980, 860evo
Case Lian Li Lancool II mesh Perf
Power Supply Corsair RM750x
Software Win10 Pro 64bit
first, I don't think turbo boost voltage is even a option in many MB bios .
I have Asus Z77 and know they don't use that option only auto, offset or manual voltage .
But if your able to use any of offset or turbo options, it saves on idle voltage state , with turbo option being best as it doesn't affect in a minus or positive way depending on setting .
So as long as your stable I would use it instead of manual , but manual will be more stable at higher oc .
Intel XTU has the turbo option for me once I am into windows , I actually do use a very small plus voltage with a small OC once I am into windows .
548 (0.08/day)
System Name Ed-PC
Why do you say, you can't turbo, just curious .
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Because it's a bs option ie just a name for llc probably, you can increase voltage but an air compressor / turbo is not going to do anything to volts ever and no pcb I have ever seen had a turbo fitted.
548 (0.08/day)
System Name Ed-PC
Well it does work, or at least the optoin in XTU works well so I assume the bios with native support of this option would give same thing .
Its gives similar results to adaptive offset in Haswell , in buy your idle is not affected and the voltage only gets added once your into boost multipliers .
No it has nothing to do with LLC AFAIK .
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
He is making a joke, turbo as in a turbocharger http://en.wikipedia.org/wiki/Turbocharger
Intel calls the high frequency mode the turbo mode. With the Gigabyte board I have, turbo mode voltage and offset voltage are the same thing. For benchmarking I used fixed voltage and for day to day I use offset.
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
It may well work as a option in a bios but imho it is important to know what is actually happening and In reality there is no actual turbo involved
From what you describe thats similar to LLC or a positive only offset and too much of it could kill a cpu as I said its just a name for a different vreg voltage control mode they could have called it nitro volts but no nitrous would be involved either.
7,111 (1.00/day)
USA
Mouse Zowie EC3-C
548 (0.08/day)
System Name Ed-PC
Yes, but with normal offset say your stock idle voltage is 1.0v , if you add say 0.1v offset your max voltage goes up but also idle is affected , same thing if you raise LLC it raises everything under any load according to the CPU VID (gets closer to this value as you raise it) .
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Llc raises everything slightly but offset is supposed to provide only what's required not extra but all these settings are initially setup and validated by the manufacturer so some vary in how they work.
Wow turbo on a pc some have pure ass for ideas lol
Now google foo up a turbo upping volts on a pc vario and I might actually be impressed.
7,111 (1.00/day)
USA
Mouse Zowie EC3-C
http://tinyurl.com/krufb56
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Troll much eh.
Are you five I advised the Op about whats actually happening and your just being an ass hat.
There is no way known to turbo volts or current.
All motherboard's have various features that effect and control the voltages in different ways and some are called stupid things that might impress a five year old but essentially do basic up and down control of the available volts or current , the end.
Steady ie locked manually set volts with no droop are whats needed for max clocks and stability.
However for most people's overclock it'sbest to use offset vvoltages and a lower max clock to harmonise max clock verses system longevity but its up to you, turbo ahead at your pleasure.
0.1 extra volts at idle in a chip made to work with way more will not hurt it.
I can almost hear the intense clicking of keys as google is hounded for proof, volts can be turbo'd
7,111 (1.00/day)
USA
Mouse Zowie EC3-C
Troll eh?
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Thats me being informative about mislabelled setting's , did it sound trolly? I apologise as it wasn't meant to
It was however a direct , truthfull , unbiased and inoffensive reply to a direct question and didn't have much to do with you .
3,842 (0.86/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
(love that pic of the rig with turbo and dump valve LOL)
Typically all voltage controls are the same, just some brands rename them.
When overclocking i like to keep it simple. Adjusting offsets (''turbo volts'' etc) can lead to instability, vdroop or voltage spikes from the fluctuations of LLC, power delays etc. If you have the time and patience to set all your offsets, idle, load and turbo mode voltages then carry on, the outcome is just about the same.
For the argument of power consumption, meh!!
965 (0.24/day)
System Name Sham Pc
Processor i5-2500k @ 4.33
Motherboard INTEL DZ77SL 50K
Cooling 2 bay res. "2L of fluid in loop" 1x480 2x360
Memory 16gb 4x4 kingstone 1600 hyper x fury black
Video Card(s) hfa2 gtx 780 @ 1306/1768 (xspc bloc)
Storage 1tb wd red 120gb kingston on the way os, 1.5Tb wd black, 3tb random WD rebrand
Display(s) cibox something or other 23" 1080p " 23 inch downstairs. 52 inch plasma downstairs 15" tft kitchen
Case 900D
Audio Device(s) on board
Power Supply xion gaming seriese 1000W (non modular) 80+ bronze
Software windows 10 pro x64
i had to give up on dynamic mode overclocking (what my intel board calls it)
i had to set my static voltages and leave it like that.
its quite confusing really. i have 2 different offsets and then a static.
if i set the static to 1.22 (what i saw the cpu used at stock under full load) then add an offset of 0.1300 to give me my 1.35 target at full load. the cpu will throttle with occt cpu oc test.
Strange though it seems it will not throttle with the psu test which puts cpu under 100% load and the gpu under 100% load.
then my other offset option is to set my static voltages at 1.35 and set the other offset to 130 (dont ask why it is numbered like that)
That Drops my idle voltages down to 1.25.. But again this causes the dumb thing to throttle..
so i was forced to set the static voltages and just not use offsets at all. for some reason that gives me a idle voltage of 1.32 and load voltage of 1.35
i have tweaked and tweaked tried all sorts of settings, but the only way i can make it not throttle when occt runs a cpu oc test is with static only..
its strange tough it wont throttle under prime. or occt psu test which is much harder on the system than then cpu oc test. but im not happy if the cpu throttles down for any reason at any time.
all this is done at 4.7ghz
i would like to also point out that if i set it to "automatic" 4.5ghz will use a whopping 1.48v so that is a big no no.
and whilst im at it. 1.35 in all detection software in windows equates to 1.3100 in the bios. when i say i set the voltages in bios to 1.35 i really set them to 1.3100 but i end up with 1.35 when im actually in my os. (this is a trait that i have seen on every motherboard and cpu i have ever over clocked so im not surprised. and thats with all offsets set to 0)
p.s
i assume "turbo voltage" is a voltage that only gets used when the cpu is in "turbo" mode which sounds like a easy way to set up offsets.
I imagine that you tell it what voltages you want to use when the cpu is in turbo mode (in my case 1.35v) and thats the end of it.
If that is how it works i would like that option my self as it would be easy for me to set up 0.95 idle. 1.35 turbo.
all these stupid offsets that cause unexpected throttling in one scenario but not in a equally or sometimes even more demanding scenario just seems like a whole lot more work than having 2 set voltages i could tell the system to use.
it is also an appropriate name if that is indeed what it does. although the word turbo does derive from turbine which obviously has nothing to do with anything. But if the word turbo in this instance is refering to the "turbo" state of the cpu then any one who has a modicum of sense would realize that its nothing to do with a mechanical turbo. and to argue the use of the word is simply trolling.
548 (0.08/day)
System Name Ed-PC
Sounds like your hitting a power limit , what wattage shows up when testing OCCT cpu test with HWmonitor or app monitoring app that shows CPU wattage .
What happens with OCCT linpack CPU test, does it throttle there to ?
Also what is temp as above 85 and OCCT as default temp limit (under config) , On power limits does your bios allow over 100% current settings . Asus has setting to like 140% depending on option , if your seeing 77-80w then that could be problem , maybe .
Edit: I see you got 2500k, I think its wattage package is 95w so forget above 77-80w which is for IB/Haswell ..
7,111 (1.00/day)
USA
Mouse Zowie EC3-C
p.s
You may have needed more to +offset than you anticipated, offset requires a lot of trial and error to get the voltage you want at 100% load.
965 (0.24/day)
System Name Sham Pc
Case 900D
i gave up on it lol. spent like 2 days with it. had occt telling me that with the offsets it was getting 1.4v at full load but still throttling. Only does it in occt cpu oc test though. Really annoying. the psu test is so much more demanding on the cpu higher temps higher usage (constant 100% vs occasional 98% dips in the oc test)
i can adjust wattage manually to allow crazy amounts before throttling. (one for always allowed to use this many watts, and then a second one that allows me to use more wats if needed for a pre defined amount of time) it also allows me to set a safe amp amount too.
if any of the safe wattage or amps get exceeded then the turbo gets dissabled. (at 4.7 the cpu uses about 108w. so i can set the safe to 110w and burst to 120w for 1s. that has it never throtteling down due to watts at static voltage.
but the stupid thing will always throttle during the oc cpu test if i use an offset. 5 seconds in it will drop ~300mhz off the speed may go lower then fluctuate after a while. and thats even when its using more voltage than i set for a static oc.
all the options for overclocking seem nice and should allow you to set over clocks that are safe stable and energy efficient. the dumb thing just wont work like that.
im pretty sure that when i set it to dynamic and then set the voltages and offests. the mother board sees what voltage i have asked for and what speeds im running at, then says "for 4.7ghz you need 1.48v so i will slow it down to make it stable"
but i dont need 1.48v thats just what "automatic" thinks i need.
and that renders dynamic mode useless.
85 (0.02/day)
Sydney, Australia
Now everything has become way too confusing. If you read the linked guide, you will see that my ASRock Z77 motherboard has such an option. Both the "Additional Turbo Voltage" and "Voltage (offset)" happen to have the save +0.xxx v unit. Ive also noticed that setting offset at, say +0.050v, gives me a very similar load vcore to setting the additional turbo at the same voltage.
85 (0.02/day)
Sydney, Australia
My motherboard pretty much treats "additional turbo voltage" (as the setting states) like an offset voltage. Having +0.051v of "additional turbo volts" gives me a very similar load Vcore to that of the similar offset voltage. I must note that all the "additional turbo volts" are in increments of +0.004v. I do believe, however, that I receive a lower vcore when idle/low-load with turbo volts being used to OV. So therefore I believe using the stupid "additional turbo volts" feature gives me better power consumption and is most likely the reason it is advised in the GUIDE i linked (initial post). Oh, and it seems to stabilize the OC just as effectively.
One thing I picked up on when trying to find my max, temp Benchmark OC is that using a high "additional turbo voltage" with a high fixed voltage caused me to BSOD before full OS boot. I was at a frequency of 4.8GHz and seemed that i should have had enough power to boot the OS otherwise. I did get 4.7 working at 1.5V however.
