Installation failed (fixed)
Ain
7 (0.00/day)
Hello.
I've recently tried updating my drivers and after the installation process and the screen flashing black i get the error message saying the installation has failed.
Last time I used this tool it was version 1.0.
I tried ddu in safe, reinstalling the OS, and not using any advanced installer features. Nothing helped.
I'm not sure what information to give you to pinpoint the issue other than that I'm on win7 x64 and installing the "445.87-desktop-win7-64bit-international-whql" drivers with only the main driver checked. My gpu is 2060 super.
Funny part is that after the failed installation the NVCleanstall shows the current version as 445.87 but the nvidia control panel won't open. I've read through the other thread with a similar issue but on https://www.nvidia.com/Download/Find.aspx?lang=en-us I didn't even find different drivers (dch/non-dch), just whql.
Same problem occurs when using nvslimmer or just plain drivers. I guess that makes it not a NVCleanstall problem specifically but I thought some of you can point me in the right direction.
I'd appreciate your help.
Regards.
250 (0.14/day)
Texas U.S.A
System Name Satan
Processor AMD 2700x with EK waterblock
Motherboard MSI X470 Gaming Pro
Cooling Custom open loop watercooled
Memory 16 GB Corsair Vengance RGB Pro @ 3466 Mhz
Video Card(s) Powercolor 5700 xt with EK full cover block
Storage Intel 660p 512 GB nvme Samsung 860 Evo 1 TB for storage SATA
Display(s) Viotek 32" curved 144 Hz 1440 P
Case Thermaltake Tower 900
Audio Device(s) Realtek onboard
Power Supply Corsair Rmx 750
Mouse Logitech G 602 wireless
Keyboard Corsair K68
Try removing the card and then reinstalling back in the slot. If you can remove the drivers from windows, do it and then try to reinstall after running DDU again.
  • Like
Reactions: Ain
Ain
7 (0.00/day)
Thanks for the quick reply. Sadly, I have no video out except for the connectors on the card. I'd have to do all of that blindly.
W1zzard
Administrator
28,606 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
The regular NVIDIA installer works? 3D apps work after the installer failed message? What does GPU-Z show?
Windows will use its Basic VGA driver so you have screen output
  • Like
Reactions: Ain
Ain
7 (0.00/day)
Thanks for the reply. No, the regular doest work either. Blindly if I remove the GPU from the PC as Craky suggested.
3d Apps work too.
Issue fixed, turns out for drivers 442.50 and up you need the SHA-2 signing updates. Those are KB4474419 and KB4490628.
Thanks to everyone who replied.
250 (0.14/day)
Texas U.S.A
System Name Satan
Glad you got it figured out Ain !
  • Like
Reactions: Ain
