Installer fails immediately with "Error: NVCleanstall settings file not found"
TheASV
4 (0.00/day)
I wanted to try out this tool for a while now but i can't install any drivers with any settings because this shows up every time the driver installer launches. I've checked the folder and "NVCleanstall.ini" and "setup.cfg" are in the folder so i don't get why it fails like this. It happens even if i bundle the installer and try installing through that.
OS: Windows 11 21H2 (64 bit) GPU: GTX 1050 Ti (Laptop but it's not reflected in it's name in the Device manager or it's specs)
W1zzard
Administrator
28,613 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
It's looking for "nvcleanstall.ini", if that doesn't exist, it shows that error.
Could you get me a screenshot of the folder with setup.exe ?
W1zzard
Administrator
28,613 (3.74/day)
Memory 48 GB
interesting .. and you right-click setup.exe and select "run as administrator" and get that error? or do you launch it in some other way?
TheASV
4 (0.00/day)
Tried both ways, it doesn't change it
Also i'm not sure if it's useful but looking at the event log setup.exe throws this exception: 0xc000041d looking it up it translates to STATUS_FATAL_USER_CALLBACK_EXCEPTION
6 (0.00/day)
I may have an add-on for this. I was getting file not found error too. So I profiled it with Process Monitor. I have attached the log from that. The setup program is looking for some VERY odd and VERY inappropriate files!!!
I am using v1.6.0, and I copied the folder out of my temp directory manually.
OK, I know why my errors happened, although the files setup.exe tried to access are still QUITE curious. When I expanded out the nvidia installer exe using 7zip, I did not pull out folders I was not going to use, such as Telemetry, Shadowplay, etc. When I tried it with a full extract folder, I got a viable installation.
This does bring to mind a potential feature request: make it so you ask what the user wants to install FIRST - then use that info to extract out ONLY the stuff that is required.
  • nVidia Graphics Driver NVCleanstall 54617.zip
