InstallShield Wizard Required installation file is missing (7z.exe) HELP
7,493 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
i by an accident choose "System Restore" instead of making a "Restore point" and after my Windows 7 Ultimate SP1 x86 booted up everytime i run a installed that uses "InstallShield" i get this message:
if anyone got a fix i would be very happy bcs, i don't have the mental energy these days to do alot and i got tired of my old Windows having to many errors lately so plz help me here, reinstalling will just exhaust me even more mentally than i am at the moment.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Reinstall 7zip?
7,493 (1.04/day)
erocker i don't even have 7z installed and if i do the same error still appears.
brandonwh64 i do have CCleaner but what should i click on off?
brandonwh64
19,542 (3.42/day)
Just run the scan and clean system files and dead registry links.
7,493 (1.04/day)
95Viper
Super Moderator
13,309 (2.20/day)
Odd you don't have 7zip on the machine, since it thinks it did.:ohwell:
Looks like your registry entries may have gotten hosed for the Windows installer (that would be 5.0 version, if using windows 7).
Windows installer can be downloaded for versions up to 4.5.
Version 5.0+ is included on your install disks or the windows 7 sdk.
About Windows Installer
Windows Installer Redistributables
Try this:
Diagnose and fix program installing and uninstalling problems automatically
or, this:
How to troubleshoot problems when you install or uninstall programs on a Windows-based computer
7,493 (1.04/day)
Try this:
or, this:
i have tired the Microsoft FixIt program it doesn't fix anything, and installing 7z doesn't do anything the setup still gives me the 7z.exe error :(
95Viper
Super Moderator
13,309 (2.20/day)
Try, either,
1. recover from the backup you made... you did backup your system, didn't you.
2. restoring to the previous restore point, before the one that hosed up the system
3. installing the the install .msi from the sdk or your windows 7 disk
4. last resort... re-install your OS
:ohwell:
587 (0.10/day)
System Name PC
Processor i5 2500k
Motherboard P8Z68-V PRO/GEN3
Cooling Fans
Memory DDR3-1600 (8GB)
Video Card(s) Sapphire Nitro+ RX 580
Storage HD103SJ
Display(s) XG2402
Case Xigmatek Midgard II
Power Supply PC Power & Cooling Silencer 750W
I ran a registry cleaner once that completely fudged my Windows Installer. After trying everything I could think of (and everything I could find online), the only fix I found was to reinstall the OS. Attempting to reinstall the Windows Installer did little, if anything, to help.
You're situation is a little different, so hopefully you'll find something before you reach the point of having to reinstall the OS.
7,493 (1.04/day)
well i got the problem solved, i simple went to C:\Program Files\ and find the folder called InstallShield Installation Information and renamed it to InstallShield Installation Information.old and than run the PowerDVD12 installation again and it just installed it no errors no nuth just installed it, so i just saved myself a reinstall ^^
587 (0.10/day)
System Name PC
Processor i5 2500k
Cooling Fans
Storage HD103SJ
Display(s) XG2402
Nice job! Glad you saved yourself the reinstall.
7,493 (1.04/day)
