Instant Boot issue
ASRockIQ
948 (0.16/day)
Daphne, AL
System Name Watermark
Processor Athlon II X4 620 @3.3GHZ V1.4250
Motherboard ASRock A780GXE/128
Cooling XIGMATEK HDT-S963 | 4 Blue LED 120mm Fans 1 Regular 120mm
Memory G.SKILL 4GB (2 x 2GB) @850MHZ
Video Card(s) Sapphire 6850 1GB (@stock)
Storage 320GB OS | 160GB Storage
Display(s) ASUS VH236H 23" 1920x1080
Case COOLER MASTER Centurion 590 (With Side Panel Window)
Power Supply Rosewill 600W 12V Rail@44
Software Windows 7 Ultimate 64-Bit Edition
Same issue as THIS Thread via other Forums what could be the issue.
Disable instant boot lol
Regardless if it's disabled, Sleep Mode nor Hibernation mode works
i disabled Hibernation and restarted my pc and then tried sleep mode again with same result as Link Posted above. me thinking about reformatting but uhh... could OC'ing be a result to Sleep mode or Hibernation not working?
I suggest you don't use any of them. What would you need to for?
uhh... i like my PC to be on. i have it set sleep @45min but the feature isn't working....
So you like to use a feature that's known to cause all sorts of problems with all sorts of computers just because you like your computer to be on at all times?
Well it is a feature that is SUPPOSE to work.... I have no issue with it at all..
Works on my rig in the sig no issue at all.
Works on two Toshiba laptops running Vista no problem at all.
I wonder to the OP do you happen to have GREEN hard drives..?
