Intel Launches Site Detailing Optane Requirements: Skylake Users Need Not Apply
22,353 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200(Running 1T no GDM)
Case Thermaltake Core X31
Microprocessor giant Intel has launched a new page dedicated to its 3D XPoint-based Optane memory solution, a technology that it jointly developed with memory manufacturer Micron back in 2015, and was supposed to be on the market by 2016. The company missed that date; however, the technology is still interesting to enthusiasts and power users alike, due to its promises of both high speed and large capacity, a seemingly unattainable combo in today's markets.
Unfortunately, it seems that any system built around when Optane was announced will not be able to run Optane-based SSDs. In the system requirements section of its page, Intel has indicated that Optane will not run on anything earlier than a Kaby Lake based CPU. No exceptions. Yes, that includes Skylake, Broadwell, and pretty much everything else besides Kaby Lake. You will also need a 200-series chipset or newer.
Skylake is amongst the most surprising of these exclusions, because it is nearly identical architecture-wise to Kaby Lake and a Skylake based chip was once used in a Optane test demonstration.
Just my (educated?) guess: at launch price, you won't want to run one of these anyway.
Can someone please explain to me how this is different than me just popping in a PCI-E m.2 SSD on my board? Seems confusing honestly
Unless money isn't a thing. But still, this kind of limitation is a reason NOT to adopt this technology. It's not like there are a lack of options. So Intel, in reference to Optane, I feel no need to replace my high-end, if older, PC for a technology that will do little in the long run. Put another way[imagine I'm holding up my hand with fingers extended], pick a finger. Can you guess which one is intended?
it's faster. supposedly.
to me it's surprise they use M.2 slot.... didn't they talk about using unused RAM slots for Optane SSD's?
Well, it points to something better from Intel coming down the pipeline because who's going to use such an endurance friendly piece of hardware with a 4 core CPU? I'm assuming they want to tank the HPC market with their next HEDT/XEON uber core chips.
But does the user just install windows on it like any other SSD or this is an aid SSD?
I would assume if you just install this in some other M.2 slot board the OS will not "see" it at install, it will probably need some kind of driver that only Kaby Lake can run.
Just a guess on my part though.
Always was under the impression that Skylake was compatible. What about the users running Skylake CPU on Z270 chipset or the other way around.
Well, it's not very unlikely initial yields are low enough and implementation problems are numerous enough that intel isn't actually aiming for mass adoption from the start. They just need to prove it works, because they hold the patents and everyone will need to license.
Edit: You got me guessing. I hate when this happens.
According to what I read, no, you need both Kaby Lake and Z270.
Good point.
LOL!
Intel said:
Intel® Optane™ memory and its logo denote a platform feature made up of individual components and not solely a single small factor solid state drive or a memory media.
Sounds like you only need kaby lake if you want to market it as "Optane"; which makes sense as they want it used with current processors.
I would guess the actual 3d xpoint drives will work on any NVMe system.
If true, that would be awesome... although it does deflate my headline a bit.
To be fair though, the whole internet is reporting it like me. ;)
All the SSDs and RAM that we have today uses a basic chip called NAND Memory Chip, so.. Optane or 3D Xpoint is another silicon, and Intel says that thays way faster and endure much more than any nand chip.
They are also based on silicon and store data, but in the fundamental level, it should be very different from nand modules.
Lets wait to see
Thats 3D Xpoint that your thinking of, which branches off of the same tech and is aimed at the enterprise market were you have tons of ram slots.
from what I've read around the net Optane SSD's are targeted at mid/low cost laptops as an alternative to pricy M.2 SSD's think of it as a hybrid hard drive solution or hard drive caching; SSD+HDD. I've read some where that there will also be an update to intel's RST software that will leverage optane as such, which in turn would validate this article as it being a driver requirement buried in RST for these things to work.
This may be a bad time for Intel to impose artificial limitations, the perception of corporate greed could trigger a mass exodus to Zen, as more people say "f**k Optane", which is, for now, just an obvious attempt to sell useless major upgrades - hey Intel, don't forget to put LEDs on these, so nerds will be able to tell it's an "upgrade"
Later, when Optane drives run from RAM slots, the speed may be there, but for now it's all hype...
It's a faster cache, correct. I don't think we will see great performance out of the m.2, but if the DIMM form is as fast as their video says, now THAT may be much better. :)
My question was if I got hypothetically an Optane drive, does it just show up as an installable volume in windows? Or do I have my windows install on an SSD normally, and the optane card acts as a booster?
Reading that seems like I'm better off saving for a nice M.2 SSD since my mobo supports PCI-e 4x SSDs
It was always KL or above, with x270 being the first chipsets having native Optane support.
It's a faster cache, correct. I do think we will see great performance out of the m.2, but if the DIMM form is as fast as their video says, now THAT may be much better. :)
There is a point where it's all just fairly redundant especially beyond sequential bandwidth at least for normal compute users and we are way beyond that point already even the very early entry SSD's were leaps and bounds faster in terms of reads than standard storage HD's where seek times were very noticeable. I mostly care most about capacity and price coming down with SSD's atm especially after the recent artificial price gouging the last 4-6 months that's sure to ensure probably for another year or two just because they can get away with it basically I mean look at high capacity HD's price hiking a few years back they dragged that out for years.
