Intel RST RAID 5 - Initialize?
33 (0.01/day)
St Brelade, JE
System Name Desktop
Processor Intel i7 5820K CPU @ 4.5Ghz
Motherboard ASUS X99-S
Cooling Corsair H90i
Memory Corsair Vengeance 64GB DDR4 @ 2400Mhz
Video Card(s) 2x EVGA GTX 1070 (SLI)
Storage 4x250GB Crucial SSDs RAID 10 (OS/Apps), 4x1TB WD Black HDDs RAID 10 (Data), 2x2TB WB Black RAID 1
Display(s) Philips BDM4350UC 43" 4K @60Hz + BenQ 27" 1080p @60Hz
Case Cooler Master HAF X
Audio Device(s) Sound Blaster Z with Logitech Z506 Speakers and Astro A50 Headset
Power Supply EVGA SuperNova G2 1000Watt
Mouse Mad Catz R.A.T 8
Keyboard Razer Chroma RGB
I've just created a RAID 5 volume from 3x2TB disks, in the RST control panel it's saying the volume is not initialized. It states this is done prior to verifying and repairing data, but do I need to initialize it now? I don't quite understand what the feature does.
I'd like to know this as well.
It syncs up every parity block. It basically does exactly as it suggests, it initializes or fully prepares, the RAID-5 parity data. If you don't initialize it, the RAID will create the parity data as needed so "free" space doesn't actually have parity. At least that's what I understand it to be. It's to ensure completeness of the parity data on your RAID. I always initialize my RAIDs, even my software RAIDs. Not that this would happen, but I wouldn't want to run the risk of any parity data being bad should the need arise that my array would need to get rebuilt.
What @Aquinus said. Just click on "Initialize" and it will work on it in the background. Just note that, until the initialization is done, the RAID5 volume will be very, very slow to respond. You don't have to do it again until a drive fails.
In fact I would say that it would respond exactly as if you were rebuilding the array because that's basically what it's doing.
