Intel Sparkle firmware?
greyltc
1 (0.00/day)
@Solaris17 Do you know why there's no firmware listed here for Sparkle's GPUs? Does this company just not update their cards' firmware?
None of them post firmware. Since the firmware is included in the driver package. Unlike AMD or Nvidia or there corresponding OEMs that may post updated firmware for specific cards.
Not necessarily, FW updates are sporadic and depend on model. This is even true if they utilize the same base chip. For example using sparkle as an example, this can mean that an update for the A770 ROC may exist when an update for the A770 ROC Luna does not.
They do have config firmware, but some vendors simply use the Intel default roms. I took a look and I do have a sparkle eco A310 here; but I have another card in my test system at the moment.
I can connect it in a few days and see which firmware will flash if any.
However; it should be noted that there cards are simple in design, even down to the PCB level. It's totally possible the rom burned is simply good enough for there cards and there is absolutely no reason to update it. Additionally, I only have a Sparkle A310 ECO. If any of the firmware flashes fail its not necessarily conclusive and does nothing to indicate if sparkle updates firmware one way or another. Its possible the default Intel roms wont flash, and if thats the case it doesnt mean Intel roms wont flash on a sparkle A770 ROC Luna; it only means it didnt flash on the card I have.
Additionally, even if it does flash, it doesnt mean that you could for example flash a Sparkle A750 in the same manner.
In either case I will have the results in a day or two if I manage to remember. I'll let you know.
Can the manufacturer supply with the VBIOS with email?
I'm on the same boat as you @greyltc
I also have a Sparkle Arc310 which I'd live to update the firmware of
It uses the stock Intel roms as I predicted:
Code:
Current date and time: Saturday, October 26 2024 12:31 PM
ARC Firmware Tool Version: 1.32.0
Now Flashing...
Do not close program while flashing is in progress!
Flashing FW File:
 "C:\Users\Administrator\Downloads\Latest_Intel_BIOS\dg2_gfx_fwupdate_SOC2.bin"
Image:  FW Version: DG02_2.2357
Device: FW Version: DG02_2.2357
Progress 1/100: 1%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 51/100:51%
Progress 58/100:58%
Progress 64/100:64%
Progress 72/100:72%
Progress 84/100:84%
Progress 100/100:100%
Flashing Oprom Data File:
Error: Failed to read:
Flashing Oprom Code File:
 "C:\Users\Administrator\Downloads\Latest_Intel_BIOS\dg2_c_oprom.rom"
OPROM CODE Version: 14 00 31 04 00 00 00 00
Installed version is newer or equal
Progress 1/100: 1%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 2/100: 2%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 3/100: 3%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 4/100: 4%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 5/100: 5%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 6/100: 6%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 7/100: 7%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 8/100: 8%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 9/100: 9%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 10/100:10%
Progress 11/100:11%
Progress 11/100:11%
Progress 11/100:11%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 12/100:12%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 13/100:13%
Progress 14/100:14%
Progress 14/100:14%
Progress 14/100:14%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 15/100:15%
Progress 16/100:16%
Progress 16/100:16%
Progress 16/100:16%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 17/100:17%
Progress 18/100:18%
Progress 18/100:18%
Progress 18/100:18%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 19/100:19%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 20/100:20%
Progress 21/100:21%
Progress 21/100:21%
Progress 21/100:21%
Progress 22/100:22%
Progress 22/100:22%
Progress 22/100:22%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 23/100:23%
Progress 24/100:24%
Progress 24/100:24%
Progress 24/100:24%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 25/100:25%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 26/100:26%
Progress 27/100:27%
Progress 27/100:27%
Progress 27/100:27%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 28/100:28%
Progress 29/100:29%
Progress 29/100:29%
Progress 29/100:29%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 30/100:30%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 31/100:31%
Progress 32/100:32%
Progress 32/100:32%
Progress 32/100:32%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 33/100:33%
Progress 34/100:34%
Progress 34/100:34%
Progress 34/100:34%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 35/100:35%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 36/100:36%
Progress 37/100:37%
Progress 37/100:37%
Progress 37/100:37%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 38/100:38%
Progress 39/100:39%
Progress 39/100:39%
Progress 39/100:39%
Progress 40/100:40%
Progress 40/100:40%
Progress 40/100:40%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 41/100:41%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 42/100:42%
Progress 43/100:43%
Progress 43/100:43%
Progress 43/100:43%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 44/100:44%
Progress 45/100:45%
Progress 45/100:45%
Progress 45/100:45%
Progress 46/100:46%
Progress 46/100:46%
Progress 46/100:46%
Progress 46/100:46%
Progress 47/100:47%
Progress 47/100:47%
Progress 99/100:99%
Flashing FW Data File:
Flashing complete!
teamdotexe.org/fwtool/ARC-Flash-log-5NARhgSekfAE.txt
I just tried your recommendation but I can't get through all the steps
1- To flash firmware I do `igsc fw update --device /dev/mei2 --image ~/dg2_gfx_fwupdate_SOC2.bin` where the bin is what I obtained from your matrix here under SOC2 (A380/A310/A40 Pro) Firmware for version 101.6129
2- To flash OPROM-Data I do `igsc oprom-data update --device /dev/mei2 --image ~/dg2_c_oprom.rom` where the rom is what I obtained from your matrix under DG2: 14 00 31 04 00 00 00 00 but then I get the following error:
OPROM DATA Version: 14 00 31 04 00 00 00 00
OPROM DATA Version: 14 00 2C 04 00 00 00 00
Error: The image is not compatible with the device, check vid/did
worked for me /shrug
Idk what tool your using, or its version, or if your driver is properly installed. You cant raw flash the cards with no driver, and you cant flash the cards with just .ini drivers. You will need the HECI software device it creates so it can communicate.
You are trying to flash a code rom _c_ with the data flag.
This wont work. Make sure you are listing the commands and look closely before trying to commit. you want oprom-code update.
Which file should I use for data then?
I don't see any specific file for Intel Arc A310
Your under the false assumption that there is one of each always. Infact that is almost never the case, with some cards never getting a _d_ data update. All the cards important metrics and functionality as explained in my other posts, pinned to the top of this forum explain this. Firmware and Oprom Code data is going to be what the user sees and feels.
I feel so dumb. Probably because I'm not familiar with any of these terms (even after having read all your other posts)
If I understand you correctly, you're saying that Sparkle doesn't publish some of the files I would need to update my Arc therefore I should not try to do it right?
No. Im saying Sparkle uses the Intel .rom files.
There are multiple files, but the ones that affect the card; fan speed, voltage, clock rate etc. Are the firmware image like "dg2_gfx_fwupdate_SOC2.bin" and the OPROM "code" file like: "dg2_c_oprom.rom".
Things like the Data oprom _d_ and config data (in the zip files I release) are things like signatures, certificates, updates to other chips on the card "if applicable".
The "if applicable" is the important part here. You may not get a new file. Straight up. Some manufacturers (like sparkle) use the intel roms. Others have super custom PCBs. But there are not one in the same. Someone like Asus might release a firmware update because they need to adjust the logic for dual fans. They might update a SINGLE file to accomplish this. While other vendors dont need such tweaks, so they will sit on the latest version until a new intel build comes out (that they can build off of) or simply use the intel roms themselves because they arent doing anything special with the PCB (sparkle).
Just because someone like Sparkle, Dell, HP do not have custom roms, does not mean that those cards are not getting updated, and it does not mean they need them, because another vendor did release one.
In sparkles case, they use the main intel firmware roms. Which means for you and most of the general public, assuming there are no problems, your sparkle card is flashed everytime you install a new driver, if Intel has released a vanilla firmware update. On windows anyway. For linux you would need to consult the matrix and do it manually. Assuming there is change.
For what its worth looking at your post:
The oprom data is the exact same as the 310 I flashed and linked before:
Your card is upto date.
Crystal clear!
Thank you so much for taking the time to explain Solaris17. I greatly appreciate it
No problem, I will update the docs when I have time to make it more clear for those searching for this kind of stuff.
