- Mar 14, 2014
- 1,514 (0.37/day)
Processor | 11900K |
Motherboard | ASRock Z590 OC Formula |
Cooling | Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas |
Memory | G. Skill Trident Z 2x16GB 3600MHz |
Video Card(s) | eVGA RTX 3090 FTW3 |
Storage | 2TB Crucial P5 Plus |
Display(s) | 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz |
Case | Lian Li Lancool MESH II RGB (I removed the RGB) |
Audio Device(s) | AKG Q701's w/ O2+ODAC (Sounds a little bright) |
Power Supply | Seasonic Prime 850 TX |
Mouse | Glorious Model D |
Keyboard | Glorious MMK2 65% Lynx MX switches |
Software | Win10 Pro |
My question is about bandwidth limits and setting custom resolutions and refresh rates to achieve a better result than the default available on certain monitors.
My situation is with a Samsung Odyssey G7 2020. This monitor is 2560x1440 @ 240Hz DisplayPort 1.4 powered by a 3080Ti.
1440p @ 240Hz with 10 bit HDR bandwidth needs exceed DP 1.4 capabilities. The next lowest option in NVCP is 144Hz. I believe the max limits should be about 205Hz for 10bit 1440p.
If I set a custom resolution with the only changing factor being the refresh to lets say 200Hz, will I be getting uncompressed 10bit HDR 1440p @ 200Hz or will there be some form of compression still happening since I am above the next lowest default in NVCP of 144Hz?
@Inle Could you possibly shed some light on this?
