- Mar 10, 2015
- 3,984 (1.08/day)
System Name | Wut? |
Processor | 3900X |
Motherboard | ASRock Taichi X570 |
Cooling | Water |
Memory | 32GB GSkill CL16 3600mhz |
Video Card(s) | Vega 56 |
Storage | 2 x AData XPG 8200 Pro 1TB |
Display(s) | 3440 x 1440 |
Case | Thermaltake Tower 900 |
Power Supply | Seasonic Prime Ultra Platinum |
Greetings,
My motherboard only has 1 internal USB 3.0 header but my case has 4 front panel usb3 ports driven off of two separate headers - needless to say, I would like to get the other two working. I do have an internal USB3.1 header that is currently unused and figured there must be an adapter to make all this work. However, the only thing I have found is this:
https://www.amazon.com/Goliton-Fron...s=usb3+header+splitter&qid=1590454136&sr=8-18
But only one of the two ports will function. There must be a way to get both of them working as 3.1 has double the bandwidth anyway. The only other thing I could really find was something like this:
https://www.amazon.com/dp/B07WG8ZJ4...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
But this is going in the wrong direction. Does my GoogleFu just suck tonight?
