ioSafe Introduces the ioSafe Solo SSD - World's First Disaster Proof External SSD
47,664 (7.43/day)
ioSafe today announced the availability of the new ioSafe Solo SSD - a solid state, highly ruggedized model of the award-winning ioSafe Solo desktop external hard drive. Combining ioSafe's new proprietary ArmorPlate, a military grade steel outer casing with SSD technology, the new ioSafe Solo SSD adds unprecedented shock, drop and crush protection to the existing fire and water protection.
The ioSafe Solo SSD combined with ArmorPlate helps to protect data in a two story building collapse, 5000 lb. crush forces, 20' drop into rubble and up to a 1000g shock. In addition the original HydroSafe, FloSafe and DataCast work to keep the drive cool during normal operation and protect the data from fires up to 1550 °F for 1/2 hour and complete water submersion of 30' for 30 days in fresh or salt water. Like all ioSafe products, the ioSafe Solo SSD comes with ioSafe's Data Recovery Service, a "no questions asked" policy to help customers recover from any data disaster including accidental deletion, virus or physical disaster.
"The new ioSafe Solo SSD is the world's most rugged and versatile desktop external hard drive. In addition to the USB interface, the new eSATA connection allows for fast data transfers and full compatibility with almost any Microsoft, MS Server, Linux or Mac operating system. The ioSafe Solo SSD can be used alone or in conjunction with any offsite or online backup strategy to add real time, zero data loss, synchronous disaster protection to any data that sits vulnerable," said ioSafe CEO, Robb Moore. "Businesses, especially small businesses, struggle with disaster recovery and regulatory compliance such as HIPAA, PCI or Sarbanes Oxley, can use ioSafe hardware to add simple, inexpensive and secure protection. The ioSafe Solo is one of the easiest, fastest and least expensive ways to protect your data."
Pricing and availability
Prices are $499 for 64 GB, $749 for 128 GB and $1250 for 256 GB. The ioSafe Solo SSD will be shipping in February 2010 and available through the ioSafe website, www.hddfiresafe.com, Ingram Micro and international distributors.
TheMailMan78
Big Member
22,598 (3.45/day)
'Merica. The Great SOUTH!
I really wish the cost of SSDs would come down.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
the SSD will likely wear out and die before that enclosure does
2,863 (0.46/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
Id say get rid of the ssd and place a engraved diamond plate with the data
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Drill a hole through a safe, route data and power cables through... plug hole with fireproof silicon. Put SSD in and enjoy.
Not as pretty as this, but much cheaper :)
2,863 (0.46/day)
Brasil
Wont be shock proof though
newfellow
314 (0.05/day)
System Name ID
Processor Q9450 ~3.74Ghz
Motherboard ASUS-P5E
Cooling Air
Memory G.Skill CL4-8GB
Video Card(s) ATI/Geforce 5850/9800
Storage A-lot
Display(s) BenQ G2400WT
Case 900
Audio Device(s) Shitty ASUS FX;P
Power Supply OCZ GXS 850W
Software -
Benchmark Scores too many machines to spec
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Fourstaff
10,091 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
OMG! DISASTER! SSD failed! What do I do? Too bad it doesnt provide failsafe for failing harddisks, the most common cause of disaster other than data recovery service which I am sure is a lengthy process.
12,173 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
I have backups run to a RADI 5 that sends out a alert to me if failure occurs, back that up to a one touch 300Gb that cost a ciouple hundred, and that goes into a a fire/water/EMP proof safe in a special cubby hole for it.
Much cheaper.
