IRQL NOT LESS OR EQUAL
911 (0.36/day)
Al Balqa', Jordan
Processor AMD Ryzen 5 2600, OC: 4.0 GHz @1.3 V
Motherboard ASRock B450 Steel Legend, BIOS Version: 10.31 [Beta]
Cooling Cooler Master MasterLiquid ML120L V2 RGB, 5x Galax Vortex Wind-02 (3x Front Intake + 2x Top exhaust)
Memory Kingston FURY Beast RGB 3600 MT/s 32 GB (4x 8GB), (KF436C17BBA/8)
Video Card(s) Palit GeForce GTX 1660 Ti Dual OC
Storage Kingston NV2 1 TB
Display(s) MSI PRO M251 (HDMI), Running @104 Hz
Case Cooler Master MasterBox MB520
Audio Device(s) HP H360G USB
Power Supply Cooler Master MWE 550 80+ White
Mouse HP G200 Black
Keyboard Redragon MITRA K551-1 RGB
Software Windows 11 Home
So yesterday i've built my friend's new PC and everything seemed fine , 2 hours later when i was at my home he send me a message telling me that it crashed ,i asked him to take a pic of the code , it says IRQL NOT LESS OR EQUAL , can you help fixing the problem ?
PC specs :
i7 8700K
ASUS PRIME Z370-A
HYPERX PREDATOR RGB 16GB (8x2)
CORSIAR H100X
MSI VENTUS RTX 2060
CORSAIR RM1000X
Nothing is overclocked instead of the GPU , i gave it a very small one +75/150 MHz.
Possibly faulty ram.
My experience with that has always been bad hardware, and yes, usually the RAM.
Only things I'd try would be re-seating "everything" and/or swapping ram slots.
After that, it's swapping pieces until you find the bad one.
Been a ram issue everytime for me
I installed the first stick in the first slot , the second stick on the third slot (counting from right to left)
It's typically a RAM problem and normally it's due to RAM voltage being too low.
Bump voltage to the sticks up and see if it goes away. As mentioned above it's possible for a stick going bad to cause it too but the common fix is a little more RAM voltage.
I see it all the time when benching and that always fixes it if anything tweaking related does.
But why would they run on a low voltage by default ?
Depends on the sticks as in the particular set.
Some just aren't quite as good as others even if compared to another, identical set.
It's also possible the default voltage in the BIOS itself as written by the boardmaker isn't quite right for the set you have.
In any instance the error you've been seeing almost always turns out to be RAM related and simply bumping up RAM voltage a little normally fixes the problem.
ram it bam it dam it, yup... hehehe :D
and yea, ram can leave the factory as bad and/or configured incorrectly, as can the mobo bios not correctly detecting the appropriate settings for the sticks you have....
Post up your voltages for CPU VCore, VCCIO, VCCST, and DRAM. Also if you could tell us the part number for the ram it would be helpful, you can get that from CPU-Z. Lastly ,do you have the latest bios update for that motherboard?
i had to bump the sa volts to run 4x8gb sticks while the stock (1.05v iirc) was fine with 4x4.
i know mines 67k but not much has changed :D
Like this?
Ok so i think the PC runs well now , i had to increase RAM voltage which was set by default to 1.19V to 1.38V (i know 1.35V was enough) , but after that the PC crashed again but this time with another code , WHEA UNCORRECTABLE ERROR , so i had to increase CPU voltage which was by default at something like 1.05V to 1.35V and everything was good.:)
Usually caused by overheating of the CPU causing an error or an unexpected shutdown
CPU temprature didn't pass 60C while stress testing.
