Is LGA 2011 better than 1150
121 (0.03/day)
System Name OLD POS
Im try to figure out should i get the i7-4770k or i7-4820k and there is a descent list of advantages to the 4820k. My question is the LGA2011 inferior to the 1150 or if not then is it possible that the chipsets are different and u can buy better mother boards for the 2011 than the 1150?
P.S. Which chipset would u guys recommend.
Thanks,
Sebastian
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
1150 is better if you just want a quadcore CPU.
Socket 2011 is better if you want 6core or 3+ GPUs or 64GB ram.
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
I'd say 1150 despite many 4770k's overclocking like shit just because of the never ending complaints I see on all 2011 boards. 1150 seems to have a lot of great boards.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
3,145 (0.64/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
It would be easier for you to tell us what are you planning to do with your computer.
It's easy to sort out though; if you know how to use more than six cores or you need 64 GB of ram or 40+ PCIe lanes then go for 2011.
If you don't then stick with 1150, because chances are that you'll only game on it.
2,074 (0.45/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
The 4820K should overclock better because the IHS is soldered on, while the 4770k uses TIM, so if you like running high OCs (or low temps), that's another reason to get the Ivy-E and one of the newer X79 boards (which have added chips for more SATA 6 GB/s and USB 3.0 ports, the latest audio chipsets, etc.). 40 PCIe lanes vs 16, quad channel memory vs dual, and an upgrade path to the world's fastest desktop processor - all good reasons to go for Ivy-E. If you manage to get a motherboard that works as advertised, you'll be golden, because if at any time in the future you feel the need for more speed or power, you can get a 6-core CPU, add more or faster RAM, and add more video cards, all without the usual bottlenecks you'd expect on the mainstream chipsets. Also, plug-and-play PCIe SSDs are becoming more common and reasonably priced, so those extra lanes will come in handy. If you are building a fairly high-end system, the prices are the same either way.
277 (0.07/day)
System Name IVY BRIDGE
Processor i7 3770K
Motherboard ASUS P8Z77-V PRO
Cooling PHANTEKS TC14PE
Memory GSKILL ARES DDR3-1600
Video Card(s) GIGABYTE GTX 770 WF OC
Storage SAMSUNG 830 / GSKILL PHOENIX / SAMSUNG F4 / SEAGATE MOMENTUS / SEAGATE HDD 1.5
Display(s) ASUS 24" / DELL 20"
Case CORSAIR AIR 540
Audio Device(s) ASUS XONAR DG
Power Supply COOLERMASTER V700
Software WINDOWS 7 ULTIMATE x64
IMO,
lga 2011 users are the elite "1%" enthusiasts PC users
while 1150 (and 1155 before it) are for mainstream PC users like most of us who want better than entry level but dont wanna venture in the top elite tier just yet.
main rig parts (cpu,mobo) will be more expensive than 1150 and ram is can be either or (especially the way prices are today)
otherwise, other components are pretty much the same.
3,288 (0.44/day)
Sunny California
Processor AMD Ryzen 7 9800X3D
Motherboard Gigabyte Aorus X870E Elite
Memory 4x16GBs DDR5 6000MHz Corsair Vengeance
Storage 2TB Samsung 990 Pro OS - 4TB Nextorage G Series Games - 8TBs WD Black Storage
Power Supply beQuiet Straight Power 12 1500W
VR HMD Pimax Crystal Light/DMAS
Software Windows 11 Pro 64bit
Thanks,
Sebastian
It depends, X79 is the way to go if you want to use 3 video cards or more natively in your system, but Z87 has a few advantages like more native SATA 3 ports, and a higher IPC from Haswell procs, it'll supposedly support Broadwell also once it's released, whereas you could say X79 is EOL, Haswell E will use X99 and a different LGA socket due to the need for DDR4 support.
X79 though still has a few tricks up its sleeve:
cadaveca
My name is Dave
17,237 (2.48/day)
SKT1150 is a "mainstream" platform. It does feature a couple of enthusiast-grade unlocked CPUs, but fundamentally, it's not really intended for high-end users, as is evident by the onboard GPU these chips include, but few of us use. Fortunately, the level of performance offered is so great that even "enthusiast" needs are met by this mainstream-grade platform.
SKT2011 is faster, overall, and is the real enthusiast platform, but today's computational needs aren't really great enough to make use of the power offered.
For me, it comes down to the number of GPUs. 1 GPU... SKT1150. 2 GPUs...SKT1150...unless you have high-end GPUs like the 290 or 290X. 3 and 4 GPU users need to go for SKT2011 too.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
They are two different animals
4,520 (0.69/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
It depends, X79 is the way to go if you want to use 3 video cards or more natively in your system, but Z87 has a few advantages like more native SATA 3 ports, and a higher IPC from Haswell procs, it'll supposedly support Broadwell also once it's released, whereas you could say X79 is EOL, Haswell E will use X89 and a different LGA socket due to the need for DDR4 support.
X89 some one needs to do some home work its X99.
Thanks,
Sebastian
I've had both i went from a 3930K to a 4770K and the 3930K is faster most likely because it has more cache, pins also the memory controller, But all depend what your using your system for the 2011 socket is overkill for 90% of the people who use it, If you plan on just playing games go for Z87 and haswell.
3,145 (0.64/day)
Mouse Logitech
Keyboard Corsair
Software Win10
I don't know what you are thinking but the 3930k is not faster because it has more cache, it was likely faster because you were using more than four cores.
Look up at the difference between 3960x and 3930k, you can't even tell the difference when looking at benchmarks because cache does not make any difference.
Same rule applies for 4930k and 4960x.
The 4770k is faster than a 3930k when only 4 cores or less are being used, the 3930k trumps the 4770k when all of its threads are being used but that's not because of the cache difference.
4,520 (0.69/day)
Perth AU
No your wrong even disabling cores on a 3930k is still slower as i see the difference on daily use as i used the 3930k from when it was released and also tested them side by side, it mite be hard to understand but the extra pins are there for more than looks.
3,145 (0.64/day)
Mouse Logitech
Keyboard Corsair
Software Win10
How have you been getting to this conclusion? Which applications or benchmarks or personal experience made your 3930k feel faster than the 4770k?
The 4770k while having less cache it still has two generations of IPC bumps, small bumps but they are there and they do make quite a difference clock per clock.
Also cache shouldn't be an argument because even though the 4770k has less cache it's still faster than the 3930k's cache.
4,520 (0.69/day)
Perth AU
I cant give you any hard proof only personal experience going from one system to another i have no reason to bag the 4770K as i own one and have no problem with it, But from experience the 3930K would load my programs and games faster using the same RAID setup and this mite not just come down to the CPU my also be the board as well, Just using my system for what i normally do i can see the 4770K falls behind in these few areas.
3,145 (0.64/day)
Mouse Logitech
Keyboard Corsair
Software Win10
Don't worry I don't need proof, I can tell you are being honest about it.
I would say there is some kind of problem related to your 4770k setup then, it shouldn't be slower or feel noticeably different than a 3930k setup, to be fair you shouldn't even be able to tell any difference!
3,007 (0.59/day)
It boils down to applications, and how much money you'd like to spend.
Assuming you run highly threaded applications (of which there are currently few outside of image processing and crunching), socket 2011 has potential. If you're a gamer or internet surfer then socket 1150 is for you.
2011:
Ability to go to 6 physical cores (12 logical threads)
8 slots of RAM possible
Higher overclocking potential due to soldered chip-lid
More Pci-e lanes
Problems with the x79 PCH (of which I've experienced many)
4 SATA II ports and 2 SATA III ports from the PCH
One generation behind the 1150 socket
EOL for this socket (SB-e and IB-e are all we get)
1150:
Integrated graphics core (a positive for debugging issues and transcoding media)
Better IMC, allowing for higher RAM overclocking
Lower general cost to ownership (though this may not always be the case)
Newer features (sleep states, integrated power management, etc....)
Potential for expansion (though not confirmed, it will likely support Broadwell)
TIM used to connect chip to lid, so much poorer overclocking potential
Less available RAM slots
Poorer ability to use multiple GPUs (though by no means no ability to crossfire/SLI)
If you're asking the question of "which is better," then the answer is likely 1150. You're unlikely to utilize the extra potential of 2011, and definitely likely to regret the difference in cost. While you can minimize the cost of the socket 2011, minimizing the cost means keeping that potential locked away.
4,520 (0.69/day)
Perth AU
The difference doesn't bother me much at all i just think some programs may like the extra memory bandwidth or so, The main thing that stands out to me is Photoshop on my 3930K i could open it up and use it right away when my 4770K has 2-3 second delay for some reason.
2,072 (0.38/day)
System Name iJayo
Processor i7 14700k
Cooling Pearless Assasi
Case O11 mini
Power Supply LIan li 750 mini
Mouse corsair Dark Saber
Keyboard Roccat Vulcan 121
Software Window 11 pro
If broadwell is 1150 compatible then 1150 for gaming / general pc usage. Running a 3820 now (other rig) planning on going 6 core ivy ...just because
3,288 (0.44/day)
Sunny California
Thanks for pointing that out, I made a typo :p it's fixed; however, my point to the OP stands, as far as future architectural updates X79 is EOL.
As for LGA2011 bigger cache or memory bandwidth advantages over LGA1150, even though the former has twice as many memory channels as the latter, this rarely ever translate to much real advantage and unless you plan on running synthetic benchmarks or memory intensive applications you won't see any difference.
Having more cores will help in multithreaded programs but the OP said he wants a quad core CPU so he shouldn't any major differences between both platforms.
Certainly not in games.
That is of course unless, he doesn't plan using multiple cards as stated before :)
As for differences in SATA performance, I own both platforms, and all things being equal, (using the same SSDs, SATA 3 in RAID 0, and a fresh OS installation) you shouldn't see any difference in performance, at least not perceptible during boot or loading times, I have to agree with what was suggested before and think that some other factor may have affcted your system...
1,683 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
The OP made one post then disappeared. I don't think he even cares about the discussion that followed. Am I imagining things or are these types of 1-post accounts becoming more common?
1,400 (0.29/day)
78°55' N, 11°56' E
System Name -aLiEn beaTs-
Processor Intel i7 11700kf @ 5.055Ghz
Motherboard MSI Z490 Unify
Cooling Corsair H115i Pro RGB
Memory G.skill Royal Silver 4400 cl17 @ 4403mhz
Video Card(s) Zotac GTX 980TI AMP!Omega Factory OC 1418MHz
Storage Intel SSD 330, Crucial SSD MX300 & MX500
Display(s) Samsung C24FG73 144HZ
Case CoolerMaster HAF 932 USB3.0
Audio Device(s) X-Fi Titanium HD @ 2.1 Bose acoustimass 5
Power Supply CoolerMaster 850W v2 gold atx 2.52
Mouse Razer viper 8k
Keyboard Logitech G19s
Software Windows 11 Pro 21h2 64Bit
Benchmark Scores ► ♪♫♪♩♬♫♪♭
If you have no interest in Ib-e 6core then get 4770K, that 4820K acts the same as 3770k in raw core perf.. and this is at least 250-350mhz slower then 4770k clock for clock.
ps, Asus Z87-WS is a good mobo for 2-3SLI or xfire, has full 2x16 pcie3.0.
Cinebench15 Single threaded test
4770k @ 4.7Ghz, 2200mhz: 188points
4930k@5Ghz,2400mhz: 188points
I tested this and compared to one member over at guru3d.
Aida64 gpgpu - check cpu side
4770k@4.6ghz
3930k @ 4.5ghz
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I'd do X79 with a 4820k or better, quad channel memory and more pcie x16 lanes. Dual channel CPU's don't like running a lot of dimms in my experience. Probably won't notice any difference in speed at all except benchmarks. Delidding sucks, never doing it again. Such a hassle. The CLU somehow dried up into white powder. It also alloyed into some weird hard to remove crud with my H100's copper because I put it on both sides of the IHS. Now my H100 warranty is voided because I'll have to lap it to get it smooth. If you get a non-soldered cpu, don't even bother trying to overclock unless you are a binning master with lots of disposable income and a microcenter near by. I've owned an i5 3570k and two 3770ks, all three suck at overclocking with really high stock vids. Delidding helps but makes you paranoid any time you pick up the computer because the damn lid could somehow dislodge.
As far as supposed per clock improvements, my Sandy i5-2550k at 5.0 ghz is quite a bit faster than a lot of stock Haswell stuff in benchmarks. 3770k isn't much slower either.
4,520 (0.69/day)
Perth AU
Delidding is easy to do you should of read up before putting it on the top side of the ihs, and theres no way the lid can come off when installed.
1,716 (0.38/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
so.... only reason to go LGA 2011 right now is if you want to run 3 or more GPU's is that correct? other than that no point?
But.... I also thought.... with a 64 bit games started to come out now..... and more and more 64 bit applications.... can we then agreed that in the near future, 6 cores will be fully utilized... making it the 6 core or more CPU's will become more future proof?
