Is there a (reliable) way to tell how many cores a game/program uses?
3,518 (0.61/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
Neither Task Manager nor Process Explorer shows anything useful in this regard. Is it even possible to monitor this somehow? Is there such software?
Haven't found anything of the sort. Since OS schedules how cores are used most of the time. The only *reliable* way to know seems to be by decompiling the executable and deobfuscating the thread instructions used for the game/program functions.
Even then you aren't going to get far if you're not good at C or Assembly language.
I'm just used to the guesswork by looking at which threads are used the most on average and decide how many of the threads are used effectively.
Some game engines give hints to how many threads are used by the use of .ini settings.
Maybe there's an idea, someone needs to make this kind of software that can do that by hooking into Direct3D for games. I wonder if it's possible to monitor exact core count usage that way, maybe if there was enough money involved. I don't know, correct me if I am wrong.
I was sceptical from the beginning, and it seems I was correct.
I play Elder Scrolls Online and I get the impression it's not optimized for more CPU cores at all, but I can't tell. Guess I never will.
Heh, War Thunder uses a single thread no matter what. It doesn't even get shared with the others, you always have "core 3" at 99% an the other 3 at 2%.
Use MSI afterburner or simply task manager while running the game and watch the core's usage, if you see something similar to 50% on a quad thread CPU, then you know the game only uses 2 threads.
Time to test the new Linux gl_thread, forced multithreading for any OpenGL game!
