Is there any difference between (Empty recycle bin) with Shred content with AVG?
108 (0.03/day)
Processor AMD FX(tm)-8320 Eight-Core Processor 3.5GHZ
Motherboard MSI Socket AM3+ 970A-G46 GLan Audio Raid
Cooling Cpu Cooler Coolermaster Hyper 212 Evo for Intel and AMD Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+
Memory RAM 8
Video Card(s) NVIDIA GeForce GTX 760
Case Nzxt Phantom Full Tower no PSU Black
Power Supply Antec Power Supply 620W ATX 24 pin High Current Gamer HCG-620 Active-PFC Retail
Software windows 10
As title says in my recycle bin i got that option and it does the same job so i was wondering if there is any difference between them:?
Hi
my understanding is as follows; File in the recycle bin will be as follows:
Windows
OriginalFileName.inf {once deleted by windows} riginalFileName.inf with first character missing with an option to restore the file. This is helpful on occasions if wrong file is deleted as the file can be reconstructed and restored, *once deleted from the recycle bin the file will be stored on the hdd platter and as long as the hdd cluster/sector has not been overwritten a recovery program could be used to fully restore the file.
AVG
Avg *should shred the file beyond recognition and write over the hdd cluster/sector where the file was stored. It would make it a lot harder to recover the data without access to some sophisticated hardware recovery tools.
Edit: To add some meat to the bone here is a quote from AVG
"AVG File Shredder provides you with an easy way to permanently and securely delete a file, folder or the Recycle Bin contents on your computer. Files deleted using AVG File Shredder cannot be recovered even with the use of advanced disk utilities.
Please note that the option to shred files is not available on locked files, USB drives, flash disks, memory cards, network drives, RAID-enabled systems and SCSI disks. The same is valid for special types of files such as symbolic links, junctions and mount points."
Source - http://www.avg.com/us-en/faq.num-5495
Other members of the TPU community may have more information
atb (all the best)
Law-II
How does this compare to ccleaner? and its "clean recycling bin" option?
Hi
My understanding is as follows:
CCleaner bypasses the recycle bin when removing files leaving no easy restore; however empties the existing files from the recycle bin when cleaning. There is an option to securely delete the file/s that CCleaner finds & removes [along the same lines as file shredding] - go to CCleaner Options, Settings; Select: "Secure deletion"
atb
Law-II
recycle bin deletes it, but doesnt overwrite it. using data recovery tools, the files can potentially be recovered.
these 'shred' options delete it, then over-write where it was on the drive with gibberish making it unrecoverable.
thats it.
thats it.
seems ccleaner does a better job since it gets rid of everything.
that has nothing to do with the OP's questions about the recycle bin?
pretty sure his question was already answered, i was simply speculating on the best of all 3 since the first question was solved. My mistake...
