itunes library
Easy Rhino
Linux Advocate
15,689 (2.32/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
I know, I know, iTunes is crap yadda yadda. Now on to my post. I have a large iTunes library on a desktop PC. I am upgrading that PC with a new HDD, etc and am wondering if I can just copy the iTunes library folder over to the new HDD and hae everything work as it should. does anyone have experience with doing that?
Yes, you can. All you need to do is go into your iTunes' preferences menu and select which folder root the data is located in.
I've done this a few times, for OTHERS not me, I promise :laugh:
Last time was Jan or Feb this year for my wife's pap. His old pc died, I removed his hdd and put it into my PC, copied the folder to my hdd; got a new pc for him and copied over the folder, and everything worked fine, looked good to me and he said it was all working. Iirc it also copies the names, play times, etc which was important for him since he named and grouped music in a particular fashion which he used for his work.
Hopefully you get it worked out. Also, many years ago I believe I did do it for myself, back when I used iTunes :)
This is the method I have used several times on my wife's computers is to just copy the iTunes Media folder. This contains all the movies and music you have in iTunes.
Just go to File Explorer > Music > iTunes > iTunes Media. Copy the whole iTunes Media folder to a USB drive (*warning* depending upon how much media you have on your drive, this folder could be quite large, so make sure you have a good 16-32GB USB flash drive. I used a USB 3.0 Adata 64GB jump drive as my wife has almost 60GB of stuff!). Then go make a cup of coffee and eat a donut because it takes a minute.
After you have all the data on the flash drive, set it aside and do your drive upgrade. Then just re-download iTunes to your new harddrive and drag the iTunes Media folder from your jump drive to replace the empty new iTunes media folder you just downloaded.
Simple and works like a charm.
Thanks everyone. Sounds like this is pretty straight forward! I won't have to re-rip hundreds of CDs now!
