ITX case with best layout and cable management?
12,453 (1.87/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
I'm getting ready to start my first ITX build, and I'm looking for a nice ITX case that's a bit on the subtle side, which is easy to work in and has reasonable cable management. I don't mind if it has a side window, but I don't want a "gamer case" or anything with a bunch of RGB nonsense. Of the dozens and dozens of systems I've built, I've never done a ITX build, so I'm hoping for some guidance from those with more SFF experience than myself.
Edit: Here are components that will be installed:
Gigabyte Aorus B450 Wifi (I think)
Ryzen 3600x
Arctic Cooling Freezer II AIO or low Profile Noctua
Asus Dual 1660 Super
Team Vulcan 16GB (8x2) DDR4
500GB NVME SSD
750w Modular PSU (Haven't decided)
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
after so many years of building full size, mid ,etc, doing a nice, clean small PC is so much fun, i loved it. iirc, i built in a SilverStone Sugo , from what i remember it was a good build
3,986 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Depends on what you need.
- No GPU - something like InWin's Chopin.
- If you want or need, even slimmer Thin-ITX is a thing.
Both above mostly use adapters and DC-DC unit in the case.
- With GPU, there will be size (and maybe shape) considerations.
- Desktop-ish large but slim cases like Fractal Node 202 or Silverstone's RVX-01.
- Small towers range from Dancase A4 SFX to towers that are almost small mATX size like Fractal Nano S.
In most cases except the largest end of the range, you will need an SFX PSU.
Coolermaster's Masterbox NR200 seems to be popular and good bang-for-buck case right now.
Lian Li TU150 is older but rather good.
18,584 (2.64/day)
System Name AlderLake
In black or white
dgianstefani
TPU Proofreader
5,448 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
Sugo for budget, Sliger or ncase for premium.
tabascosauz
8,304 (2.31/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
If you're prioritizing traditional "cable management" features, you most likely will not be finding anything that's SFF. O11 Mini, H200...easy to find, not too expensive, with easy cable management, but they are anything but small.
For the rest of the SFF space, you're looking towards custom sleeves cables if you want it to look neat. If you're sticking with stock cables in something reasonably spacious like the NR200, then eliminating all SATA drives and going to NVMe only will keep a lot of the clutter down.
  • If you want a traditional familiar layout (as in what you'd find in a midtower, just in a smaller package), you're looking at cases like the Streacom DA2, NCASE M1, CM NR200(P), Cougar QBX, Sliger S610/S620. As there is no space behind the board tray for cable management, you're going to want to take an hour or two to work out your cable management, looking to tuck things where there is empty space and gently coaxing things to run the way you want them to go.
  • If you don't have serious CPU cooling needs (5900/5950X, 10700/10900K) and you can make do with a 120mm AIO or L12/L12S, then sandwich cases may make your cable management a little easier and give you better GPU thermals in the process. DAN-A4, Ghost S1, FormD T1, SM550/560/570/580 all fall into this category.
  • The HTPC layout with the board flat has been around a long time and is still a decent choice for NAS/media usage. Not a lot of radiator support, temps usually unimpressive. SG05/06/08/13/14, Node 202, CM Elite 110/130 all fall into this category. The smaller cases place the PSU dirextly overtop the board, resulting in thoroughly disappointing CPU cooling performance, again it depends on what you're putting in it. Cable management is often pretty hard in cases like the SG05, SG08 and Elite.
  • Then there's the vertical cases - Evolv Shift, H1 (obviously not a consideration at the moment), SSUPD, etc. Can't tell you much about these aside from that they exist, and sandwich cases still have better GPU thermals sometimes.
I'm not sure what exactly you're putting in this build, so I can't really go any further into even smaller GPU-less territory.
I can vouch for the Silverstone SG08 (no longer available, unfortunately, SG14 is a shitty revamp), NCASE M1 (I have a v5), and the Sliger S610/620 (I have the mATX Cerberus from which they are derived). In that sense, the CM NR200 is an excellent choice for beginners as it offers the M1 layout with more space to work with.
dgianstefani
TPU Proofreader
5,448 (2.04/day)
Swansea, Wales
Sandwich cases are perfectly compatible with "serious cpu cooling needs" you just don't use air cooling. Also they are compatible with a lot more than just a single 120mm aio lmfao.
The sm570 and 580 for example can take up to 2 240/280mm radiators in a custom loop, or 240/280mm aios.
NCase m1 also supports twin 240mm radiators.
I would suggest doing some more research before advising others.
2,002 (0.55/day)
Seattle, WA
So this is admittedly a hard case to get still, and not exactly the smallest SFF case at 17.5L, but I recently tracked down and switched my main build to Streacom's DA2 and it's been excellent. I've previously used the Node 304 and 202 and both served well; the Node 304 still being one of my favorite SFF cases to build in. The DA2 is a bit of a puzzle to work out the rail system, but RTFM where they give examples of layouts based on what parts you intend to use, what rails can be put where to support components, etc and it becomes pretty easy to work with.
Than you'll probably like the spec sheet for the DA2 in regards to RGB.
dgianstefani
TPU Proofreader
5,448 (2.04/day)
Swansea, Wales
12,453 (1.87/day)
I'm going to update the OP with the components that are (and those most likely) to go into the case.
In black or white
I really like this case, but it might be a bit wider than I'm wanting.
freeagent
10,368 (4.29/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I have a Define C Mini TG.. its probably a little bigger than you need.. I bought mine by mistake but I cant wait to use it! Its not a tiny case, but its smaller then a Meshify C which is tiny compared to my R4 :D
There is probably a better case out there..
12,453 (1.87/day)
Actually, this is one of the cases already on my list. I've had really good luck with Fractal cases in the past. They always seem to just make sense.
Edit: Actually, I had been looking at the Nano S
SL2
2,527 (0.36/day)
A 750 W PSU is overkill IMO. The 3600X + 1660 Super will never go beyond 300 W. Pick one 450 W or more and you'll be fine.
This also opens up the possibility for SFX/SFX-L PSU's, which in turn gives you more options for cases.
The O11 isn't just a bit wider, it's an ATX case with 43 l in volume:
The Define C Mini TG (Micro-ATX) isn't really small either at 33 l. That's exactly 1 liter larger than the Dark Flash DLM21 in your specs.
The Nano S is smaller at 27 l, but it's actually longer (15.7") than the DLM21 (14.5")
Volume, footprint, ATX or SFX PSU size, expandability.. I don't know what you need, I'm just assuming you want something smaller than what you already got.
Pick any case you want, but remember that a smaller motherboard alone doesn't make an SFF build. ;)
12,453 (1.87/day)
Great post. Thanks for the very detailed information. You are probably right to a point with the psu, however I'm always one to leave room for future upgrades, so maybe a 550w or 650w. Any suggestions for a chasis that's actually small and easy to work with?
  • Like
Reactions: SL2
SL2
2,527 (0.36/day)
I don't have experience with the current models, but I think the NR200 seems worth checking out. The SSUPD is about as small but can be used with regular ATX PSU's which is a plus if you want something fairly quiet.
Streacom DA2. Looks great, expensive, hard to find.
SSUPD looks great, but it's new and it's not out yet.
Review.
Also, check out that channel, it gives you a good insight into the SSF world. I'd say videos really helps giving you a sense for how small the cases are, which isn't really needed for any other components or regular cases.
12,453 (1.87/day)
Review.
That SSUPD case looks fantastic. I think it might be EXACTLY what I'm looking for!
  • Like
Reactions: SL2
SL2
2,527 (0.36/day)
Yeah, I like it a lot, that small footprint is appealing. No point in using a "SFF" case that has the same footprint as a mid tower if you're asking me.
Never been a fan of glass doors anyway.
Here's a nice quick test of several cases, just remember that you're not pushing it like he does with CPU/GPU choice.
