- Dec 14, 2015
- 79 (0.02/day)
System Name | ACXtreme |
Processor | Ryzen 4 7800x3d |
Motherboard | Arous xtreme x670e |
Cooling | Artic cooling artic freezer II 420 |
Memory | T force rgb ddr5 6000 |
Video Card(s) | Rx7800xt nitro+ & Sapphire R9 390 NITRO with back plate |
Storage | 990 pro nvme samsung |
Display(s) | 34" ultra wide rgb |
Case | ANTEC performance 1 |
Audio Device(s) | Sound blaster |
Power Supply | Evga supernova 1000w |
Mouse | 502 protocols core or something like that |
Keyboard | G910 "Logitech" romer g switches |
Software | Windows 11 |
Benchmark Scores | 4600+ heaven |
even though I have all power saving settings off, nothing seems to keep my clock speed from changing. My HT speed along with my NB and cpu core clock and memory clock is always changing. (I can't find anyone experiencing the same thing - I've seen no proof that this is normal when overclocking etc.)
I'm making changes to my bios such as increasing voltages but no monitoring program seems to read any of them out correctly. (my NB voltage reads out as the default value in all the monitoring programs I have used so I don't know if the changes such as this is even being made when I do them in the bios if they don't show when I get into windows)
I'm not trying to lay a list of issues that I have but i'm ready to overclock more and make sure my rig is right and nothing is giving any issues that could hold me back like a hot northbridge and maybe too high of a memory clock with too low of dram voltage.
I have a feeling that for some reason something is not getting enough voltage and is making my northbridge overheat sense it is the one component on my motherboard that even seems to get hot while everything else is a normal "low" warm easy to touch. (the most I could find out is that it seems that raising the right voltage could remove a heat related issue and make things normal and cool).
I'm trying to work this out so I'll learn and know what to expect, (no doubt I can find a better motherboard such as the latest top tier 990fx board that gigabyte has out, sense it has a heat pipe that connects the VRM, NB, and SB all together so I assume that is optimum. Can I get some help please so maybe I'll learn what I need to know (I'll get a multimeter so I can use that too).
I 1st want to know why my BLCK is always changing though and never really ever staying at just one speed "set" but it's always got to be moving for some reason always going up and down the change is small but it still shows in most monitoring programs along with the bios also showing it change. I assumed it was normal but it's the 1st on my list to find out if it is or not.
