- Dec 2, 2009
- 3,353 (0.59/day)
System Name | Dark Stealth |
Processor | Ryzen 5 5600x |
Motherboard | Gigabyte B450M Gaming rev 1.0 |
Cooling | Snowman, arctic p12 x2 fans |
Memory | 16x2 DDR4 Corsair Dominator Pro |
Video Card(s) | 3080 10gb |
Storage | 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD |
Display(s) | HP Omen 34c (34" monitor 3440x1440 165Hz VA panel) |
Case | Zalman S2 |
Power Supply | Corsair 750TX |
Mouse | Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery |
Keyboard | Custom mechanical keyboard tm680 |
Software | Windows 11 |
Benchmark Scores | 70-80 fps 3440x1440 on cyberpunk 2077 max settings |
A friend of mine gave me a java sudoku ready, i just modified the main part but looks like it
doesn't show up anything (used the code in neatbeans and in eclipse too):
Where the problem is here? It compiles perfectly! Nothing shows on the screen
Code:
package javaapplication2;
import java.util.*;
public class Main {
public static void main(String args[]){}
Random generator = new Random();
int[] serie = new int[9];
int[][] sudoku = new int[9][9];
int[][] select = new int[9][9];
int livello;
public Main(int livello) {
this.livello = livello;
for (int i=0; i<9; i++) {
for (int j=0; j<9; j++) {
select[i][j] = -1;
sudoku[i][j] = -1;
serie[i] = -1;
private void genArray() {
int numCas = Math.abs(generator.nextInt(9))+1;
for (int i=0; i<9;i++) {
if (i==0) {
serie[i] = numCas;
} else {
while (serie[0] == numCas ||
serie[1] == numCas ||
serie[2] == numCas ||
serie[3] == numCas ||
serie[4] == numCas ||
serie[5] == numCas ||
serie[6] == numCas ||
serie[7] == numCas ||
serie[8] == numCas) {
serie[i] = numCas;
private void generateSudoku() {
if (i==0) {
for (int k=0; k<9; k++) {
sudoku[i][k] = serie[k];
} else if (i==2) {
for (int k=0; k<6; k++) {
sudoku[i][k+3] = serie[k];
for (int k=0; k<3; k++) {
sudoku[i][k] = serie[k+6];
} else if (i==1) {
sudoku[i][k+6] = serie[k];
sudoku[i][k] = serie[k+3];
} else if (i==3) {
for (int k=0; k<8; k++) {
sudoku[i][k+1] = serie[k];
for (int k=0; k<1; k++) {
sudoku[i][k] = serie[k+8];
} else if (i==5) {
for (int k=0; k<5; k++) {
sudoku[i][k+4] = serie[k];
for (int k=0; k<4; k++) {
sudoku[i][k] = serie[k+5];
} else if (i==4) {
for (int k=0; k<2; k++) {
sudoku[i][k+7] = serie[k];
for (int k=0; k<7; k++) {
sudoku[i][k] = serie[k+2];
} else if (i==6) {
sudoku[i][k+2] = serie[k];
sudoku[i][k] = serie[k+7];
} else if (i==8) {
sudoku[i][k+5] = serie[k];
sudoku[i][k] = serie[k+4];
} else if (i==7) {
sudoku[i][k+8] = serie[k];
sudoku[i][k] = serie[k+1];
System.out.print(sudoku[i][j] + " ");
System.out.println("");
arrange();
private void arrange() {
int cas = Math.abs(generator.nextInt(3));
if (cas == 0) {
if (i == 0) {
swap0(i);
} else if (i == 3) {
swap0(i);
} else if (i == 6) {
swap0(i);
} else if (cas == 1) {
if (i == 0) {
swap1(i);
swap1(i);
swap1(i);
} else if (cas == 2) {
if (i == 0) {
swap2(i);
swap2(i);
swap2(i);
private void swap0(int pivot) {
int aux;
aux = sudoku[pivot][j];
sudoku[pivot][j] = sudoku[pivot+1][j];
sudoku[pivot+1][j] = aux;
aux = sudoku[pivot+1][j];
sudoku[pivot+1][j] = sudoku[pivot+2][j];
sudoku[pivot+2][j] = aux;
aux = sudoku[j][pivot];
sudoku[j][pivot] = sudoku[j][pivot+2];
sudoku[j][pivot+2] = aux;
private void swap1(int pivot) {
int aux;
sudoku[pivot][j] = sudoku[pivot+2][j];
sudoku[j][pivot] = sudoku[j][pivot+1];
sudoku[j][pivot+1] = aux;
aux = sudoku[j][pivot+1];
sudoku[j][pivot+1] = sudoku[j][pivot+2];
private void swap2(int pivot) {
int aux;
public void select() {
int numX;
int numY;
genArray();
generateSudoku();
if (livello == 0) {
for (int i=0; i<30; i++) {
numX = Math.abs(generator.nextInt(9));
numY = Math.abs(generator.nextInt(9));
while (select[numX][numY] != -1) {
select[numX][numY] = sudoku[numX][numY];
} else if (livello == 1) {
for (int i=0; i<20; i++) {
} else if (livello == 2) {
for (int i=0; i<10; i++) {
try {
notifyAll();
} catch (Exception e) {
