KFA2 4090 SG 1clickOC below average score in Port royale
48 (0.02/day)
System Name 7900x / 4090
Processor Ryzen 7900x
Motherboard B650E Aorus Elite X Ax Ice
Cooling Liquid Freezer III 280mm
Memory Gskill trident z RGB neo 6000mhz 36/36/36/96
Video Card(s) Kfa2 RTX 4090 sg-1click oc
Storage Nvme pcie 4 Kingston Fury 2tb
Display(s) LG Oled 42” c2
Case HYTE y60
Audio Device(s) Audioengine A2+
Power Supply FSP Hydro 1000w atx3
Mouse Logitech G502lightspeed
VR HMD Quest 3
Hi Everyone guys, I need help with my new GPU, a KFA2 4090 SG 1clickOC. I just installed it on a recently formatted PC (down below the spec) and I noticed that the score in Port Royal is under the average: 21800
I tried to configure the card in NCP but nothing worked.
Vsync and Gsync are disabled in Nvidia control Panel
maximum performance in the power management
Freq 2580 for the gpu clock10501 memory clock
TDP In Xtreme Tuner is on 100%
61°c temp 1050 mv voltage
In HWINFO and GPUZ i see that the max tdp reached is 92,6%
Config spec:
120hz 4k display res. (LG c2 42")
Ryzen 7900X
DDR5 32gb 6000 mhz CL19
X670 Gaming AX Gigabyte
2TB Fury NVME 7500MB/s
KFA2 4090 SG 1click OC
latest GPU drivers 537.42
No idea temps look fine here is my run bone stock.
As far as I know there is no such thing as DDR5 6000 CL19
What power supply are you using?
You're absolutely right... my mistake (i was thinking at the other PC i have with DDR4 :D)
these are the ram CORSAIR VENGEANCE RGB DDR5 32GB 2X16GB 6000MHZ C40 1.35V CMH32GX5M2B6000C40, (i fixed in the first post)
This is the PSU
BeQuiet PowerZone 1000w https://www.bequiet.com/en/powersupply/384
is 2580 on the gpu a little low, i think my TUF is running arround 2800 ish...
I will test when i get home
This is from afterburner. I don’t know why if I make the screenshot directly from the app, the data are wrong …
to be fair. the average score in 3DMark especially on high end cards is massively influenced by all the extreme OC results.
my gaming x trio is slightly below average 2.8GHz in almost all bechmarks.
I made two things: I removed the riser cable (I had a pcie4 riser for the vertical mount) and lowered the ddr5 to 4800mhz instead of 6000, as I found some instability on the ram. The score is now 25600
