- Apr 10, 2024
- 4 (0.01/day)
Processor | AMD Ryzen 7 5800X3D |
Motherboard | ASUS CROSSHAIR VIII HERO |
Cooling | Arctic Liquid Freezer III 420 |
Memory | G.SKILL TridentZ Neo 32GB 3600mt/s RGB F4-3600C16D-32GTZNC |
Video Card(s) | AORUS RTX 3070 Ti MASTER |
Storage | 2TB KC3000+1TB SAMSUNG 970 Pro+500GB OCZ Trion 150 |
Display(s) | LG UltraGear 27GS85Q-B |
Case | BE QUIET! SHADOW BASE 800 FX |
Power Supply | ASUS STRIX 1000W PLATINUM ATX 3.1 |
Mouse | LAMZU MAYA X | ATK Z1 Ultra | IPI FLOAT 88 | VXE MAD R MAJOR+ | ZAOPIN Z1 PRO | ATK A9 PRO MAX |
Keyboard | YUNZII RT75 |
Hi guys!
I have a 2TB KC3000 as my main system drive installed in my X570 Hero in the first M.2 slot with the mobo included heatsink installed. I have peeled the plastic off the thermal pad. Ever since I had the drive in my system the drive temperature 3 sensor reports a constant temperature of 78 celsius. Is my unit defective?
The other temp sensor seems to be fine and reports temps just fine. I checked with AIDA and HWinfo but I see the same temperatures being reported. Should I RMA the drive or is this supposed be normal?
