Kingston SSD firmware update issues
1,571 (0.29/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w LG SC9S Dolby/DTS | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Hello everyone, I am posting after a very long time related to a issue I am having with my SSD. I have a Kingston HyperX 3K 240 GB SSD (SH103S3240G) with firmware version 580ABBF0. I have seen that my drive performs slower than other same model drives in reviews etc with different firmware versions. So I went to Kingston official page and downloaded the firmware 526ABBF0. However, when I try to update it, it says no firmware update available. On further digging, I have found that the firmware version my SSD has is not for the HyperX 3K series at all. I am really confused about this issue. I am sure I have configured Windows the way it should be done for a SSD (TRIM running, indexing disabled etc). I am running the entire system in AHCI mode.
Other drives I have installed are
1. WD10EARS - SATA II
2. ST380817AS - SATA I
3. ST500DM002 - SATA III
4. WD5000BPVt - SATA II
5. LG GH22NS50 ODD
So anyone who can shed some light on this issue?
Note: I have got this drive as a prize in the HyperX OC Takeover held on August 2014 at HWBot.
maybe i can help u...
i also have the same ssd drive with some other ssd&hdd drives..
all my ssd are working properly but i wanted to do firmware update out of boring...
what i noticed is that i could update all ssd's that were connected to mainboard's (intel's) main (black)sata ports,
and the 240gb kingston ssd was connected to marvells(extra grey sata port near the black standard sata ports)
and only that ssd it couldn't find firmware with kingston ssd updater tool.
So check this maybe it will help u.
i've heard the same thing about firmware updates - try it on the primary ports, and try IDE mode instead of AHCI/RAID (can be annoying if windows is on the SSD you want updated)
no dont do any switches to ide
ffs its ssd drive with already installed windows in ahci mode
Yes I though about this. The thing is my motherboard has all the SATA ports connected to the AMD SB 950 chipset and connected to the SATA_1 port on the motherboard. Any other ideas?
I am going to try this right now. Though I have Windows installed on the SSD itself. Thanks Mussels.
Also, I have a Kingston HyperX Fury 240 GB SSD lying around. Which is better? The Fury or the HyperX 3K?
The Fury seems to be having an edge in performance but want your opinion.
Update: I just tried IDE mode. Windows booted up, installed some drivers and asked for a reboot. Did it but firmware update showed the same message. :(
I think it will boot on IDE too. Else I will mod the registry and check out.
some DOS based firmware update tools require it. try and understand what you're talking about before posting.
This is the performance I am getting. I don't feel it is consistent and I expect better from the SSD.
AMD chipset drivers are also updated.
what sata port is it on?
The first SATA port on the motherboard. All SATA ports come from the AMD chipset.
is it running in AHCI mode, and which drivers? AMD or microsoft?
Maybe i reacted to quickly, pardon me sir!
