Kolink Observatory HF Mesh and Unity Alpha Cases at Computex 2025
47,853 (7.38/day)
Kokink at the 2025 Computex showcased its two premium mid-tower cases, the Kolink Observatory HF Mesh, and the Kolink Unity Alpha. The Observatory HF Mesh is a variant of the original Kolink Observatory, that comes with a mesh intake and pre-installed fans, designed for positive air pressure inside the case. It features three 140 mm Kolink Umbra ARGB intake fans, and three 120 mm top exhausts for rapid airflow inside the case. The case offers clearance for graphics cards up to 33 cm in length, CPU coolers up to 16 cm in height, and PSUs up to 18 cm in length.
The Kolink Unity Alpha is a glasshouse case with a horizontally partitioned layout. Tempered glass takes up the left side and front panels. The motherboard tray offers plenty of space on the backside for cable management, but is recessed toward the front end, so fans or radiators pointing sideways don't get in the way of long graphics cards. The case comes with two side-facing reverse-blade ARGB fans pre-installed, besides a 120 mm rear exhaust.
