- Jan 3, 2015
- 3,077 (0.81/day)
System Name | The beast and the little runt. |
Processor | Ryzen 5 5600X - Ryzen 9 5950X |
Motherboard | ASUS ROG STRIX B550-I GAMING - ASUS ROG Crosshair VIII Dark Hero X570 |
Cooling | Noctua NH-L9x65 SE-AM4a - NH-D15 chromax.black with IPPC Industrial 3000 RPM 120/140 MM fans. |
Memory | G.SKILL TRIDENT Z ROYAL GOLD/SILVER 32 GB (2 x 16 GB and 4 x 8 GB) 3600 MHz CL14-15-15-35 1.45 volts |
Video Card(s) | GIGABYTE RTX 4060 OC LOW PROFILE - GIGABYTE RTX 4090 GAMING OC |
Storage | Samsung 980 PRO 1 TB + 2 TB - Samsung 870 EVO 4 TB - 2 x WD RED PRO 16 GB + WD ULTRASTAR 22 TB |
Display(s) | Asus 27" TUF VG27AQL1A and a Dell 24" for dual setup |
Case | Phanteks Enthoo 719/LUXE 2 BLACK |
Audio Device(s) | Onboard on both boards |
Power Supply | Phanteks Revolt X 1200W |
Mouse | Logitech G903 Lightspeed Wireless Gaming Mouse |
Keyboard | Logitech G910 Orion Spectrum |
Software | WINDOWS 10 PRO 64 BITS on both systems |
Benchmark Scores | Se more about my 2 in 1 system here: kortlink.dk/2ca4x |
Some of you have might seen, i am planning to build a 2 in 1 case pc and for that project. I am intending to only use one monitor and one keyboard/mouse.
So do any of you know a good kvm switch that support at least one monitor at 1440P and 120 Hz (dual monitor support, would be nice to have. Cause you never know down the road i if would be going dual monitor setup) via HDMI 2.0 or display port. This is importent as i will be gaming throw that switch as well. If 4K 120 hz is possible, that would be even better.
What are other people´s exsperience with gaming throw a kvm switch. Is it input lag nightmare or fine for that perpose.
I am totally blank on kvm switch. So i have little to none knowlegde of these switches. So if people know and can tell about things i shut be aware of, specially when it comes to gaming as i fear latency/inputlag might be a problem.
If some one has another solution, i am also open for other ideas.
