Hewlett-Packard
HP Flat panel monitor L1955!!!
Features
Performance*: Typical brightness level of 250 nits, extra-high contrast ratio of up to 1000:1, superior scaling, 16 ms response rate, and sharp 1280 x 1024 resolution on a large 19-inch viewable screen offer crisp image clarity while helping improve visibility
Compatibility: Standard 15-pin D-sub analog and advanced DVI digital interfaces help maximize your technology investment by allowing a smooth transition from legacy applications to the latest digital graphics standards; the integrated 4-port USB hub enables quick and easy connection to a variety of devices
Ease of use: Plug and Play convenience offers easy setup and maintenance; a wide range of icon-based on-screen controls allows quick customization of the display to match user preferences; HP Display LiteSaver allows you to preset Sleep mode and extend the monitor life
Flexibility: Thin bezels on all four sides let you "tile" up to four panels for panoramic viewing of large data displays on trading floors or other data-intensive environments; the lightweight design and a "quick-release" detachable base make mounting, handling, and shipping easier
Ergonomics: Adjustable screen height, tilt, swivel, and 90-degree pivot features, along with 176 x 176 degree viewing angles let you customize your viewing position and select landscape or portrait orientation
Environmental design: HP monitors are held to high recycling standards, are certified for low emissions, and are compliant with Energy Star and most major international standards
Options: The HP Flat Panel Speaker Bar (sold separately) is powered directly by the monitor and seamlessly attaches to the monitor's bezel to bring full multimedia support with dual speakers with full sound range and external jack for headphones
