- Mar 5, 2012
- 299 (0.06/day)
- Dubai, UAE
System Name | RTX 5090 Machine-to-be.... |
Processor | AMD Ryzen™ 7 9800X3D - Hopefully order won't be cancelled :D |
Motherboard | Asus B650E-E ROG Strix |
Cooling | Thermalright Peerless Assassin 120 SE |
Memory | Acer Predator Vesta II 32GB (16GB * 2) DDR5 6000MT/s CL30-38-38-76 |
Video Card(s) | HP GT730 2GB DDR3 Mighty Edition!! |
Display(s) | Acer Predator X35 G-Sync Ultimate |
Case | Lian-Li O11 Air Mini Black-Mesh |
Power Supply | Toughpower GF3 1200W Gold - TT Premium Edition |
Mouse | Logitech G502 Hero wired |
Keyboard | Corsair K70 RGB PRO |
VR HMD | Nope NOpe NOPE |
Software | Windows 11 Pro |
Benchmark Scores | Nothing special...Yet. |
Hi all, this is a friend of mine PC and we are planning to squeeze powerful hardware in a very small sized case, our choice for case will be
Fractal Design Arc Mini
The Specs to be cooled are :
1 - MoBo : Asus Maximus V Gene , Here , Since this model and the Z68 one share the same specs in this point.
2 - CPU : 2700K , Here , the goal is to work on 5GHz with the lowest Vlt and Temps.
3 - Dual EVGA GTX670 FTW + 2 * These 1 2 , also this one Here to connect the GPUs together.
Ok, the question is what pump can help me to put all of this in one loop? and if so, can i combine this pump with a resvoir combo like this one here "Since i am limited with the space".
and other question is what is/are the best Rad configuration for this loop? should i combine all in this new 120 Rad for the whole loop? if so, what Fans do u suggest for it?
and if it doesn't work, i consider going to a 140mm + 120mm slim rads, one on the top and one on the lower part vertically using the HDD Space, "I will handle the HDDs some how
" , what are your suggestions?
for the fittings and tubing i am going for the 3/8G tubing size, other than this i think this liquid cooling system will be fine and amazing too, costing all like 750-800$, waiting ur help TPUations
