Left Ctrl key not registering - Logitech G910
400 (0.13/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz)
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Razer Basilisk v3
Keyboard Logitech G910
Software Windows 10 64bit
I'm trying to find a solution to the following problem.
I have a brand new Logitech G910 keyboard and the Left Ctrl Key and the left Windows key do not register at all...
I've got the keyboard rgb configured to illuminate in red when I press a key... All the other keyboard keys work fine.
Including the RIGHT ctrl and windows key but not the left ones.
Any suggestions as to how to potentially fix this problem?
Long story short literally your keyboard is toggled into 'game mode' where it locks out stuff like the ctrl and windows keys to prevent accidental activation.
FInd out how to put your keyboard back into normal mode and that should fix the problem - I dont have a logitech gaming keyboard, nor have i had one so youre on your own. Usually its some software you gotta install to get all your macro keys working. So if you aint installed the logitech software - that would be the first place to start.
