- May 21, 2024
- 1,374 (3.64/day)
LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, announces the launch of the HYDROSHIFT II LCD-C series AIOs. Designed with side-mounted, flexible tubing and a compact radiator, the new AIO provides a clean, nearly tubeless appearance while maximizing compatibility with various case layouts. The HYDROSHIFT II features a sleek, cable-free pump block with a mounting screw cover and a unique latch-in-place design that simplifies installation and enhances maneuverability. It also features a 2.1" round LCD display with full L-Connect 3 integration and offers three versatile control modes: Offline, Wireless, and USB-Streaming.
Minimalist Tubing, Maximum Flexibility
The HYDROSHIFT II LCD-C refines the series' signature clean aesthetic with a more compact radiator and a redesigned side-mounted tube design, achieving a nearly tubeless look and maximizing compatibility. The flexible server-grade corrugated tubing ensures smooth bends around the radiator without compromising flow or internal diameter. A sliding tube clamp allows for precise tube alignment directly over the CPU block and can be secured to 140 mm fan brackets to lock the tubes in place. For builds with limited clearance, the clamp can be removed to optimize space. Paired with a newly redesigned 400×122×24 mm radiator, the HYDROSHIFT II LCD-C offers broad case compatibility while maintaining effective heat dissipation in a wide range of PC setups. The HYDROSHIFT II also features a sleek, cable-free pump block design with a clean mounting screw cover, complemented by an innovative latch-in-place mounting mechanism that holds the block securely while users screw it down—making installation easier and more manageable.
Round LCD with 3 Control Modes
The HYDROSHIFT II LCD-C features a vibrant 2.1-inch IPS round display with a resolution of 480x480, 500 nits of brightness, and a 60 Hz refresh rate. It offers three flexible control modes to accommodate different use cases.
Fan Options for Every Build
The HYDROSHIFT II LCD-C 360TL comes pre-installed with UNI FAN TL Wireless fans, offering premium performance with speeds up to 2600 RPM, 90.1 CFM airflow, 3.97 mm H₂O static pressure, and a maximum noise level of 33 dBA. The 360CL features UNI FAN CL Wireless fans, designed for quiet operation and maximum efficiency. With a speed range of up to 2200 RPM, 72 CFM airflow, 3.0 mm H₂O static pressure, and a maximum noise level of 31 dBA, the CL Wireless fans offer reliable cooling performance. For users building a custom setup, the 360N model ships without fans, providing full flexibility to choose and configure fans based on system needs and preferences.
Availability and Pricing
The HYDROSHIFT II LCD-C, in both black and in white, is available in three configurations: the 360TL, pre-installed with UNI FAN TL Wireless at an MSRP of $239.99; the 360CL, pre-installed with UNI FAN CL Wireless at an MSRP of $179.99; and the 360N fanless option at an MSRP of $159.99. All models are backed by a 6-year warranty.
- Offline Mode allows for a plug-and-play experience without the need for USB connections or additional software. The pump block has a rotatable cap for intuitive adjustments: turning it clockwise cycles through 13 preset LCD backgrounds, while turning it counterclockwise changes the lighting effects. In this mode, essential data such as coolant temperature and pump RPM are displayed, with fan and pump speeds following a preset curve based on coolant temperature. For the 360CL model, the cap also adjusts the fan RGB effects.
- Wireless Mode, enabled by the L-Wireless Sync Controller, connects over a 2.4 GHz signal and provides screen and lighting control through L-Connect 3 without relying on motherboard USB headers. This mode provides real-time access to system sensors, including CPU and GPU usage, temperature, as well as synchronized lighting and speed control of compatible TL/CL Wireless fans and the AIO pump.
- USB Streaming Mode offers full customization via L-Connect 3, allowing users to upload JPGs, GIFs, and MP4s, apply modular templates, and even use the display as a secondary screen. This creates a fully personalized visual experience.
