Lian Li O11D - Front Mesh Mod using O11D Evo Mesh Kit
66 (0.02/day)
System Name Nebula
Processor Ryzen 9 7900 @5.4 GHZ
Motherboard Gigabyte B650 GAMING X AX
Cooling Custom Loop - Bykski 60mm x360 mm RAD + Byskski 45x360 mm RAD+ Barrow 30x360mm RAD + D5 Pump+Res
Memory TEAMGROUP T-Force Vulcan Alpha DDR5 Ram 32GB Kit (2x16GB) 6000MHz RED
Video Card(s) Asus Strix OC 3080 12G on Phanteks Glacier Chrome Waterblock
Storage Adata XPG S40G 1TB, Crucial MX500 1TB, WD SN 570 1TB , Seagate Barracuda 2TB
Display(s) Acer XV272U 2560x1440 @144Hz
Case PC O11 Dynamic White, with Custom Front Fan Mod Total 13 Fans
Power Supply Phanteks Revolt Pro 850W
Mouse Cooler Master MM720
Software Win 11 Pro
Benchmark Scores R23 Multi: 30K CPUZ Multi: 12450
I have Lian li O11 D original white case, i intent to use three radiators, fitment was not the problem at all. But airflow was bad.
I setupp fans as side and bottom intake and top exhaust. Since Side and Bottom both intake has radiator(s) it heats the air coming into the case.
I realized any intake air from the fans on the radiator(s) is actually warm-hot when pc is in load, and it re-circulates to other rads eventually warming them instead.
So if i had to use 3 radiators all radiator fans on them should blow air out of the case and not it. But case should have cold air coming in too...
I modded my case for better air flow and got my self front mesh kit. Used this: LINK
so for this mode i added:
1. LINK 92mm FR-925 RGB WHITE- on rear side, as Intake - Used Sillicon tappe to set the fan in place
2. LINK Lian Li O11 D Evo front mesh Kit - Used Neo Dymium magnets to lock the panel in front, since original o11D does not has the fitment for it. Added 3 fans as intake sticking with mesh.
4. I have now Top: 60x360mm + 30x360mm Radiator on bottom + 45x360mm Radiator on Side all Fans are exhaust
5. I think it had worked out ok, except from side there's 0.8mm gap due to magnets and fans in front.
What u guys think?? :PPP
