Light Scribe disks and software??
CUSACKOTG
50 (0.01/day)
Processor AMD athlon 3000 (venice?)
Motherboard ABIT SLI AN8 Guru
Cooling Thermaltake fans all over the case
Memory 2 X 512mb Geil DDR 400
Video Card(s) X800 ATI Radeon
Storage 37gb Raptor WD- 10000Rpm
Display(s) 21 inch Hp p1130 - NOT lcd but a killer mon anyway
Case Thermaltake Soprano
Audio Device(s) WANTING one
Power Supply 430w Thermaltake
Software I want a version of LINUX that does all (i have xp)
Just wanted to know if anyone knows how to burn cd's with the colours that we see on disks bought from shops- i have some lightscribe disks that ive been burning which are all green in colour but i want to be able to manipulate the colours on the disk- how is this possible? Does the disk colour determine the colour or can you manipulate the colours
thanks in a dvance
i don't think you can change the colors. it just uses a laser to burn in the image. and burnt-color is burnt-color. you could try changing discs to get different colors maybe.
I have lightscribe, all you can do is black and white. Buy a special printer for CD's and buy inkjet acceptable CD's and you can do what you see on albums of artists and such. Be sure to buy high gloss cd's if you can find em.
