- Aug 12, 2005
- 754 (0.10/day)
Processor | Intel Core i7 4790K |
Motherboard | Asus Z97i Plus |
Cooling | Antec Kuhler 620 + Gentle Typhoon 3000RPM |
Memory | A-DATA XPG V2 DDR3-2400 16GB |
Video Card(s) | MSI GTX 970 Gaming 4G |
Storage | Samsung 850 Ev0 500GB |
Display(s) | Qnix QX2710 @100Hz |
Case | Silverstone SG13 |
Audio Device(s) | Onboard |
Power Supply | Silverstone SX-500LG |
Mouse | Logitech G602 |
Keyboard | Corsair K70 Lux |
Software | Windows 10 Pro |
Benchmark Scores | Not interested in benchmarks |
I spilled some drink on the keyboard and few keys started getting sticky so i took it off and cleaned those keys. but now the left shift + i doesn't work anymore. i'm having so much trouble typing the capital i. right shift + i does work, but i am not used to using that combination.
i took it apart again, and tried just hitting the "rubber" and then it worked. but i couldn't get the "keys" to work after assembling. i left it like that and few keys i missed that day started getting sticky again so i disassembled it and cleaned those keys. but left shift + i still doesn't work. i checked it the rubber works. (means, the keys don't push the rubber enough) pressing the rubber doesn't work either. left shift with all the other keys work. simple i works. just the left shift + i doesn't work.
one more thing; when i press them together, it doesn't print anything. not even a simple i instead of I. looks as if the signal goes to the processor, but cannot identify what they are?
what can i do to fix this? (it is not a corrupted driver either. i reinstalled windows couple of days ago and installed the same driver that used to work well before this problem)
