I have a lot of experience using CAD and 3D-based software. For my GPU, I prefer the PNY A series. I use my GPU in water-cooled systems, and I'm not sure about the amount of RAM required on the GPU. However, based on your budget, I would recommend getting the best PNY A series card you can afford secondhand. Personally, I have the A6 with 48GB of RAM, which I purchased secondhand (2 years ago) for about half the price of retail. Since the GPU prices are stable for this particular card, I could sell it for what I paid for it right now. I chose the 48GB version because, in the world of CAD and 3D, everything is getting bigger and more complex with time. I have no issues with my card keeping up, and the support on professional-based cards is excellent. I've had some great conversations with PNY about the professional cards. Although there is a newer version of my card out now, there is no reason to spend 7K on something like that. I made the switch at the time to get something that would take care of my needs without taxing my system. In my opinion, the 3090s were all over the place, and I actually had a system based on a dual 3090 at first. However, out of all the GPUs available, I feel that A6000 is the best choice. When I tested the results between the dual 3090 and single A6000, the A6000 performed better each time. Additionally, the A6000 has better thermals.
Just the other day I was checking out the A2s on Ebay; they are less than 500 bucks for sure.
Right now I am building a smaller system, and that GPU I have I will use, until. Would it be nice to get the current edition sure, but at $7K, its not worth it. I will wait until they get to 50 off second hand
