Looking to upgrade my front intake
52 (0.02/day)
Sydney, New South Wales, Australia
Processor AMD Ryzen 7 3700X
Motherboard ASUS Strix X470-i
Cooling Alphacool Eisbaer LT240, 2x Corsair LL120, 1x Noctua 3k RPM fan
Memory G.Skill TridentZ 16GB DDR4
Video Card(s) GALAX RTX 2080
Storage Samsung 970 EVO 1TB NVMe boot, 2x 2TB Samsung 860 QVO in RAID 0
Display(s) Dell U2719D, AOC e2343F
Case Corsair 380T
Audio Device(s) Steinburg UR12, Beyerdynamics DT 990 Pro, ModMic 5
Power Supply SeaSonic Focus Plus 750W
Mouse Logitech MX Master, Razer Viper
Keyboard Ducky One 2
Hello there, I'm looking to replace my two front fans that came with my case to some DC 140mm fans. The reason why I would prefer to use DC fans is that my motherboard only has two fan headers & I want to utilize my fan controller. I have been looking at the Be Quiet Silent Wings 3 and the Fractal Dynamic x2 GP-14 fans. Please post your fan suggestions that I will also be able to obtain in Australia.
DC?
Ether one of those is fine
got me ..... i have no idea either.
why not post the store/stores you shop with/at?? I live in the US, and for any other members not in AU, it will save us from googling what stores are in your region. Just post a link to 1 or 2 of your stores.
i dont know if they are available in your region, but....
Scythe
Fractal
Phanteks
Noctua
are good fans to name a few, but all makers have shit models, so its bets to pick the model that suits your need
Scythe
Fractal
Phanteks
Noctua
Scorptec Computers
Umart
Mwave
PC Case Gear
Here u go :)
What is your sound/cooling preference? Some people put up with a hum in order to have the coolest system possible, others demand silence, where do you fall on that spectrum? Do you want PWM? What is your budget?
I love my Noctua redux fans, PWM control, very quiet bearings, great airflow. https://www.newegg.com/Product/Product.aspx?Item=9SIAADY4AW8188 These replaced the stock Corsair sleeve bearing fans that came with my H110, greatly reducing the noise, while keeping same or better temps and airflow. Also, they come in neutral gray/black colors, so no crazy Noctua brown.
Get Glidestream 140s, they have no lights but are good fans for noise and performance.
DC or DCV = Direct Current as opposed to PWM
Was a time when I wanted all my fans to be PWM, but I don't anymore.
1. PWM's advantage was excellent low speed control. The constant 12V allowed fans to start up with enough oomph to overcome inertia and get the blades moving. DCV OTOH, when low speeds were called for could not overcome that inertia. Downside to PWM ... a) cost b) low speed hum / ticking noises and some brands (particularly Corsair, ya couldn't gang many on a single channel.
2. These days, MoBos utilities have gotten sophisticated enough to start up the DCV fans with a bit more oomph and thaen trail back once blades are moving. You can even call for fands to stoip below a certain rpm and ramp speeds up and down. The later is useful for water cooled systems subject to varying laods which eliminates the whiring sound accompanying rapid load chnages and all lets the fans seep running at higher speeds sor a time to remove hear from coolant. Also, DCV fan design has improved such that they now perform at speeds comparable to PWM.
3. We also have fan control PCBs which will take a PWM signal and control say (6) DCV fans on a single channel with no auxillary power cable.
As for fans ... for the most part, there's not much difference between fans ... that's for the **MOST** part. http://www.overclockersclub.com/reviews/phenteks_f140/3.htm
Here we see that replacing the venerable NF-A15's for example on a Noctua Cooler with Phantels fans drops CPU temps by about 3C ... however, the Noctua fans are 1500 rpm, and the tested Phanteks fans are only 1200. Running that both at 1200 rpm and the Phanteks fans drop CPU temps by 6C. That's a pretty astounding change.
4. Martin (of martinsliquidlab) isn't around to do the massive fan comparisons he did back in the day and much of the data is now questionable as the days of hi fpi radiators are well in the past and high SP is not needed any more. The last decent size roundup i saw was here:
http://www.silentpcreview.com/article1345-page7.html
... with the top ten at the time being 1) Phanteks PH-F140HP/TS, 2) Noctua NF-A14 FLX, 3) Noctua NF-A15 PWM, Noiseblocker B12-2, Noctua NF-P14 FLX, Scythe Gentle Typhoon 120-12. Noiseblocker M12-S1, Corsair AF120 Quiet, Corsair AF120 Performance, Thermalright TR-TY150
Since then two fans have impressed me, ... the Silent Wings 3 and the as yet unreleased Noctua strengthened blade designs w/ minimal blade clearance. That leaves the Wings to consider and from what I have see I think they are as good or perhaps even better than the Phanteks ... but at more than twice the price, ... I have 16 fans in my box (10 rad / 6 case), I'm not gonna invest in a swap. I usually grab a dozen PH-F140SPs at a time ... they are bout $10 each every cupla weeks on newegg... about $8.50 for the 120mm. The Wings on the other hand run about twice that for the 140s and 2.5 times for the 120's. Always looking to learn about new stuff, so if ya see anything, please list.
I use Rheostats for mine
I prefer Yate Loon D14BH-12 with 4 pin PWM, cost about $10 from Chinese ebayers. You have to put your own 4 pin plug on them, but otherwise they are amazing. Can be silent at very low speeds or move 150 cfm with a acceptable roar.
