Lossless scaling
75 (0.22/day)
Motherboard MSI Pro B550M-VC Wifi
Memory 2x16GB G.Skill RipJaws DDR4-3600 CL16
Video Card(s) Asus DUAL OC RTX 4070 Super
Storage 4TB NVME, 2TB SATA SSD, 4TB SATA HDD
Display(s) Dell S2722DGM 27" Curved VA 1440p 165hz
Case Fractal Design Pop Air MIni
Power Supply Corsair RMe 750W 80+ Gold
Keyboard GMMK TKL RGB Black
VR HMD Oculus Quest 2
What's the deal with lossless scaling? Does it actually deliver on it's promises? Is it worth using if you have a capable modern GPU and there's a native upscaling and frame gen solution in the game you're playing?
1,110 (0.61/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
The trouble with Lossless scaling is, that it's behind a paywall & also technically DRM too.
I was wondering why reviewers haven't come across comparing other upscalers so far & this maybe the main reason.
Features such as D.L.S.S, F.S.R, & X.e.S.S are technically free as long the hardware you buy supports the versions of it.
My opinion is that these features were "not technically free" either as the prices of cards have increased substantially with their inclusion. Sometimes more the triple or quadruple their original tier pricing. It is no doubt that Nvidia running a A.I machine for 6 years straight endless for D.L.S.S contributed to the cost of increasing their cards prices. The price of that usages power isn't free.
The dual GPU/Frame gen think looks interesting since you get iGPU's to run the algorithm, & not need two of the same cards.
3,634 (1.13/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
It works but don't expect non-native implementations of DLSS / FSR to work as well as native ones for the most part.
Better yet just use Magpie. It's free and more flexable than lossless scaling.
17,908 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
i have lossless scaling on steam, it requires a lot of math to get it to work right, like you have to know your resolution then what scaling to use, etc. i honestly find it more annoying than useful. i still haven't found a good use case for it yet, i wasted 5 bucks on it, but oh well.
1,476 (0.22/day)
Noir York
Case AIGO Darkflash C285
I use lossless scaling for frame gen in Cyberpunk, it works well for intended purpose, works better than DLSS, less blurry. Works very well with little artifacts when framerate above 30fps. I tried frame gen on my laptop while iGPU do the frame gen (Intel UHD on i5 11400H) and dGPU (RTX 3050) run the game. It didn't work as well as I'd hoped.
367 (0.77/day)
I used it back when driver-based integer scaling was not an option for my video card due to greedy vendor. The developer has since added a tonne more features. It's worth every penny, in my opinion.
92 (0.86/day)
System Name Bargain System
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550 Gaming Plus
Cooling Deepcool LT720 360mm
Memory 32GB Corsair Dominator Platinum DDR4 3600Mhz
Video Card(s) Zotac RTX 4080 AMP Extreme AIRO White Edition
Storage Western Digital SN850X
Display(s) Acer Nitro 34" Ultrawide | Samsung Odyssey G5 27"
Case Lianli O11 Dynamic Evo White
Audio Device(s) HiVi Swans OS-10 Bookshelf Speakers
Power Supply Seasonic Prime GX-1000 80+ Gold
Mouse Razer Ultimate | Razer Naga Pro
Keyboard Razer Huntsman Tournament Edition
It works but at the same time doesn't work very well. Based on my experience using it for a short period of time on my old RTX 3090, the performance hit was a lot higher when compared to using hardware based upscaling like DLSS. The image quality is also not as good compared to DLSS 3, which is to be expected. Maybe it would compare more favorably with FSR 2 or 3.
I didn't bother to try the frame gen because I could just use FSR 3 frame gen instead.
167 (0.08/day)
System Name Ryżem
Processor AMD ryzen 2700
Motherboard MSI b450 tomahawk
Cooling Silentiumpc grandis 2
Memory 2x8gb corsair venegance
Video Card(s) Gigabyte Gaming OC 9070 XT
Storage 500 GB Samsung 970 Evo plus, 3tb Toshiba p300, 1tb WD blue
Display(s) I must check.
Case Dell xps 630
Audio Device(s) Integrated
Power Supply Some Flower need to check
Mouse Must check
Keyboard Motospeed ck104
VR HMD HTC vive pro
Software Dunno, changing to linux
I was using Lossless scaling as means to view Youtube in 3k that was only in 1080p :D, You can scale any window, and for older games, or games that are in low res this is quite fun, I've upscaled Baba is You that it has almost now borderlines, and textures are nicer for eye.
Upscaled
Not upscaled
I'm thinking of using it as scaler for old tv shows that are in 720 or 1080.
1,614 (0.31/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
"Lossless scaling" sounds like an oxymoron to me...
1,614 (0.31/day)
It refers to the Integer Scaling they started out with.
I got that, I still think it doesn't make much sense. "Lossless" was used in the context of data compression because the operation was meant to be reversed. Scaling changes the data for end consumption. In the cases where stuff are scaled as compression means, all scaling would be lossy.
114 (0.08/day)
System Name desktop
Processor Ryzen 9800X3d
Motherboard Asrock Pro Rs
Memory G.Skill Flare X5 6000mhz cl30 1.35v
Video Card(s) Asus GeForce RTX 4080 TUF Gaming - OC Edition
Storage 2TB WD_BLACK SN850X NVMe
Display(s) Acer Predator 1440p
Case Fractal R6
I did try it a couple times but seemed more trouble than its worth since native just works better right now.
367 (0.77/day)
Integer Scaling takes each pixel from the input and multiplies it. At 2x scaling, each source pixel is replaced by a 2x2 square with the same color. Not a single bit of source data is lost or compressed, and the process is reversible. Contrast with commonly used bilinear interpolation scaling which is lossy and causes blur.
1,614 (0.31/day)
"Blur" is not "loss." Both bilinear and nearest-neighbour upscaled images would still contain the original data. Reversal maths would be complicated in bilinear case (not by much, if the original grid structure was simply subdivided), no doubt. But, and this was is the point here: Reversal is not required or considered here in the first place!
367 (0.77/day)
I hope you're making sense to someone because you're certainly not making any sense to me. Integer scaling will remain lossless regardless of how you feel about it. This application was named accurately based on that fact. We're done here.
252 (0.06/day)
Processor Ryzen 7 5800x3D
Motherboard Gigabyte B550 Gaming X v2
Memory Corsair Vengeance LPX 2x32GB 3600Mhz C18
Video Card(s) XFX RX 6800 XT Merc 319
Storage Kingston KC2500 2TB NVMe + Crucial MX100 256GB + Samsung 860QVO 1TB + Samsung Spinpoint F3 500GB HDD
Display(s) Samsung CJG5 27" 144 Hz QHD
Case Phanteks Eclipse P360A DRGB Black + 3x Thermalright TL-C12C-S ARGB
Audio Device(s) Logitech X530 5.1 + Logitech G35 7.1 Headset
Power Supply Cougar GEX850 80+ Gold
Mouse Razer Viper 8K
Keyboard Logitech G105
For the upscaling part, Lossless Scaling is not really that impressive. It's not really better than driver level upscaling of AMD and Nvidia. But it is easily applicapable to pretty much any game and video source so it has its uses.
In Frame Generation, Lossless Scaling actually does something neither AMD nor Nvidia havent thought of yet and I think it is brilliant. Dare I say, it will the way to follow for FG in coming years. And that is something called Adaptive Frame Generation.
What Adaptive mode in LS does is instead of sticking with 2x, 3x, 4x, 10x generation frames as usual, it sticks to a given target framerate. You basically input your monitor refresh rate and you always get that many frames in a second. So you always get the benefit of increased motion fluidity from FG as much as you can see on your monitor. This is better than fixed mode lock to your monitor refresh rate. Because you dont lose fluidity in a heavier scene if your card cant handle nor you have to stick with increased input lag when scene is much easier to run since fixed modes lock you to certain base ingame framerate. And it just much more easier to use as you dont need try to find a good framerate/quality setting to use FG at its best.
And LS uses a Flow Scale to predict motion in frames where you can adjust to increase motion fluidity by lowering FG overhead. I'd say whole experience is pretty close to AFMF2 so it's actually pretty enjoyable.
Of course in game FG has it's motion vector advantages, but LS can work in any game on any card. You dont even have to have a card actually, it runs on integrated graphics too.
So all in all, I think LS dev does something great. Though it can never actually beat natively supported DLSS, FSR or XeSS, it is more accessible than them and actually has the potential to lead the FG tech to better implementations.
2,888 (0.47/day)
Northants. UK
System Name Bad Moon Ryzen
Processor Ryzen 5 5600X
Motherboard Asrock B450M Pro4-F
Cooling Vetroo V5
Memory 16Gb (8gb x 2) 3200 MHz DDR 4
Video Card(s) GTX 1080
Storage Samsung 860 Evo 500Gb SSD, Samsung 860 Evo 1Tb SSD
Display(s) Asus VG249Q3A (180Hz Freesync/Gsync) & 4K Samsung TV
Case Fractal Design Meshify 2 Compact w/Dark Tempered Glass
Power Supply MSI MPG A850GF (850w)
VR HMD Rift S
Personally,with a big library of games, I have used it on those titles that were locked at 30 or 60 on PC. I'm now able to play those same games at a framegenned 180Hz with extreme fluidity, no corruption and minimal input lag. It really feels great.
NSR
117 (2.09/day)
I like it for making videos smoother but I prefer my AFMF2 as an FG alternative in games. It's simpler and feels more responsive to me. Could be placebo.
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
I know you are correct but you have to remember the target audience here is largely gamers and they really don't care how it works as long as it does.
I don't mean that as insult to gamers by the way. We all get there at some point. It's fine to want to kick back and not care how the pixels occured on your screen.
