Low FPS in Path of Exile 2
maD_Ghoul
2 (0.01/day)
I recently installed a new game to play and found that I have super low FPS (around 10). Fiddling with the settings of the game and it's only made a slight difference even though the game now looks as if it was made in the late 90s.
This experience led me to explore a lot of options in order to fix the issue but nothing has really helped. My laptop isn't anything amazing but it should be able to handle the game according to the official recommended hardware specs.
I stumbled upon GPU-Z in a forum post that explained that additional M.2 SSD drives might be interfering with the GPU in some way limiting its 'lanes'. After running GPU-Z though I find that my Bus Interface is "N/A". I tried the render test and even started games as stated to see an actual result but to no avial. The Bus Interface still says "N/A".
I have a Lenovo ThinkPad E14 Gen 2 laptop and as mentioned above I recently added a 80mm M.2 1TB SSD to it. That's the only hardware change done to the laptop. As far as I am aware all drivers are up to date.
Needless to say - I am very new to any of this so any and all help will be much appreciated!
Thanks,
Filip
30 (0.02/day)
Processor Intel Core Ultra 9 285K | NGU 3,2GHz | D2D 3,2GHz
Motherboard MSI MAG Z890 TOMAHAWK WIFI | BIOS 1.A73
Cooling Noctua NH-D15 G2 | ARCTIC MX-6
Memory G.Skill Trident Z5 RGB 96GB (2x48GB) DDR5 6400MHz | CL32-39-39-102-141-701-2T | 1,35V | Gear 2
Video Card(s) MSI GeForce RTX 5080 VANGUARD SOC 16GB
Storage Intel Optane 900P 280GB | WD Black 10TB WD101FZBX
Display(s) AOC AG274QZM 27“ 2560 x 1440 10bit 240Hz
Case Lian Li O11 Air Mini Black
Audio Device(s) Creative Sound Blaster AE-7 | Audio-Technica ATH-A990Z
Power Supply be quiet! Dark Power 13 750W
Mouse Logitech G MX518
Keyboard Logitech G213 Prodigy
Software Windows 11 Pro x64 24H2
You need to use driver for Path of Exile 2 which is version 32.0.101.6319. According to the GPU-Z screen you have driver version 32.0.101.5972 installed. Not sure if it will be playable but it will run much better than it is running now. Bus Interface is N/A because it's iGPU of your CPU (it's part of it and it isn't some device on PCI-E bus) so that's normal. I have no idea what resolution you are trying but on 2560 x 1440 with the lowest settings possible without upscaling or dynamic resolution it's unplayable on Arc based iGPU of 285K with 28FPS just standing still and dropping to single digits in action. So I expect that you will need to use these tricks to get to at least barely playable level.
338 (2.06/day)
System Name le fish au chocolat
Processor AMD Ryzen 7 5950X
Motherboard ASRock B550 Phantom Gaming 4
Cooling Peerless Assassin 120 SE
Memory 2x 16GB (32 GB) G.Skill RipJaws V DDR4-3600 DIMM CL16-19-19-39
Video Card(s) RX 9070XT XFX
Storage 2 x 1 TB NVME & 2 x 4 TB SATA SSD in Raid 0
Display(s) MSI Optix MAG274QRF-QD
Power Supply 750 Watt EVGA SuperNOVA G5
I heard in another thread on this site that multi-threading is disabled as a default setting (not sure why that's an option). Maybe it helps with your performance
3,103 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
" NVIDIA® GeForce® GTX 960 or ATI Radeon™ RX 470"
your iGPU is not even in the same universe compared to a 960. it's maybe 15% of a GTX 960 in the absolute best, cherrypicked case.
maD_Ghoul
2 (0.01/day)
You need to use driver for Path of Exile 2 which is version 32.0.101.6319. According to the GPU-Z screen you have driver version 32.0.101.5972 installed. Not sure if it will be playable but it will run much better than it is running now. Bus Interface is N/A because it's iGPU of your CPU (it's part of it and it isn't some device on PCI-E bus) so that's normal. I have no idea what resolution you are trying but on 2560 x 1440 with lowest settings possible without upscaling or dynamic resolution it's unplayable on Arc based iGPU of 285K with 28FPS just standing still and dropping to single digits in action. So I expect that you will need to use these tricks to get to at least playable level.
Thanks a lot for the detailed info! Super useful!
Told ya I know nothing! =]] I've been missled by basically all other games I've ever wanted running OK on the laptop. Guess I don't play GPU intensive games :p
1,828 (1.09/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
GPU-Z is showing inaccurate specification for your graphics solution, but you have the Intel Xe Graphics with either 80 or 96 Execution Units (EUs).
Unfortunately, your integrated graphics is well below the minimum requirements to play the game. The listed minimums of AMD Radeon RX470 or Intel ARC A380 are about 3x more powerful. Also, this game needs at least 8 GB of RAM and 3 GB of dedicated VRAM. Using integrated graphics, you'll need at least 12 GB of system RAM installed.
Your Xe Graphics is technically able to run PoE2, but its rendering power is too low for a playable experience.
