Low gpu usage dx11 bf5 every game
Status
Not open for further replies.
62 (0.04/day)
Processor Ryzen 5 5600x
Motherboard Asrock B450M Steel Legend
Cooling Freezer 34 eSports DUO
Memory Kingston HyperX 16GB 3200mhz
Video Card(s) PALIT GeForce RTX 4070 GamingPro 12GB
Storage 1TB Toshiba Hard Disk
Display(s) MSI Optix G27C5 165Hz
Case Cougar DuoFace Pro RGB black
Audio Device(s) Razer BlackShark V2 X
Power Supply FSP GROUP HYDRO G PRO ATX3.0(PCIE5.0) 1000W
Mouse Glorious Model O
Keyboard Razer Huntsman TE
Battlefield V Low gpu usage GTX 1660 TI RYZEN 7 2700X 16GB 3200MHZ Future Frame Rendering On
Just watch the video.
Every thing is put on high performance in nvidia control panel, from control panel etc.
650W Be quiet high quality psu.
75hz monitor
Native resolution.
I have this problem from a while i have tryed everything.
I Cannot answer now!! when i can.
18,584 (2.63/day)
System Name AlderLake
Looks fine to me.
44,274 (6.80/day)
Reinstall Windows,clean slate
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Looks fine, BFV is very CPU intensive, you'll rarely see full GPU use unless you play at 4K or something like that.
the54thvoid
Super Intoxicated Moderator
13,586 (2.42/day)
Memory 32GB Kingston Fury
Video Card(s) MSI RTX 5080 Vanguard SOC
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Please use your existing thread for this discussion.
Multiple threads for the same topic (same GPU and same low usage) will incur points.
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
you run a 2700X and have a massive CPU bottleneck
you'll have CPU bottlenecks at 4k with a 12900k... depending on what's going on.
Status
