M2N-E problem
pt
not a suicide-bomber
8,956 (1.27/day)
Portugal
Processor AMD Turion 64 X2 Mobile TL-60 (Trinidad)
Motherboard ASUS F3Ka (ATI RS690M)
Cooling stock
Memory Nanya 2x1GB ddr2 667@5-5-5-15-2T
Video Card(s) ATI Mobility Radeon HD2600 512MB DDR2@ 580mhz/486mhz
Storage 160GB on laptop+250GB external
Display(s) ASUS 15.4
Case Asus Laptop F3Ka chassis
Audio Device(s) on-board
Power Supply 1:30minutes battery
Software "genui xp", 'cause i hated vista
New board and already a problem..... :shadedshu
I recently bought a Asus M2N-E board and all worked fine until the electricity gone down, after i got electricity i turn on the computer and doesn't have internet, windows says that there aren't any "web card" i reinstall the drivers and still don't work, any ideias?
Take your card out, boot into windows, then shut down and put the card back in? I sure hope that's not the integrated network you're talking about :p. If that doesn't fix it you should try a NIC from a friend. If it work, the powerout somehow killed your NIC, and if it doesn't work, then windows lost a few critical files. Boot from the windows start disk, act like you're going to intall windows XP, and then hit "R" for repair. Don't go into repair console though, that's an entirely different thing. Good luck.
Its onboard, but i cant make it work with a card either, what is a NIC?
NIC is shorthand for Network Interface Card. Alright you're probably going to have to repair windows. See my first post to tell you how :p.
Repair didn't work so i reformat it and work, thanks, doesn't know which was the problem
Well I sure hope you didn't have anything important on there before you reformatted :laugh:.
