Mac G5 Case Mod
peche
Thermaltake fanboy
6,709 (1.75/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
I Saw this mod several time ago, I wanted to make mine, I got the case but the ideas and imagination flew away … it's there any owner of one similar mod with the same case that may help me out?:D
Regards,
t_ski
Former Staff
11,941 (1.72/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
115 (0.03/day)
Regards,
Iam working on Mac G5, to mod it. How can ı help you.
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
im not interestet on keep any of Original parts on my mod, just the case, also i have no idea how the front panel works, the on &off bottoms for example, thats the unique part i may be interested to use of it, rest will be replaced with aftermarket stuff...
115 (0.03/day)
thanks a lot arg-ist, first of all, im looking forward how hardware could be into the case, and also with the om/off buttoms, seems little bit complicated, i like the case because it has good space, also dont know exactply how the back part must be cut and replaced,
for example:
Regards,
There are alot of mods with this case.
I am not interested too, with original parts . I used only empty case.To use it with an ATX MB you must change the backside of the case . becouse of I/O slots and fanns..
You can make a half mask like this
and mount it as back panel
or you can use a MB tray with backpanel
and mount it so
My goals fort his Project were preserve the look of the case at outside ;and fit my PC s hardware including a full ATX MB. And watercooling. and used original fan grills.
Therefor ı draw at corel a new backpanel komplet, an cut them at waterjet
Bended it as original
You can see it at coming days.
Todays ı am busy doing a different watercooling system fort his case.
You can write me if you have any questions to
arg-ist@hotmail.com
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
and mount it so
This would help me pretty much, cuase one of my bigest problems its back part of case, having his solved whit a complete stand or plate to add my ATX and other components the task its half done...!
i would look for a sorce to buy someting like it ...
i may ask about where you recomend to place PSU ?
115 (0.03/day)
The main problem is PSU and their place. this is my
and as MB and backpanel you use it from an old case.
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
Seems a good place to put it, I was wondering to place it mostly in the middle of the case, but that maybe a good place,
I'm planning to get my current hardware there, so there should be enough space for:
· Full ATX Board
· 2 HDD's, 1 SSD,
· PSU
· Thermaltake Water3.0 Pro.
· Optical Drive
· At least 5 Fans, 3 Front, 2 Exhaust,
I'm pretty sure there is more space than I need, I'm pretty sure it will work, and could be nice If I can take advantage of almost every inch of free space in, mostly for a good cable management and air flow,
peche
Thermaltake fanboy
6,709 (1.75/day)
System Name Athenna
mod not started yet... :(
