I'm new here, so go easy on me
I wasn't sure if I should post this on the video card forum or the Mac forum, so if I put this in the wrong place, just let me know.
I have a Mac Pro 1,1 with 16 GB RAM. I was so frustrated because it couldn't run any of the Mac OS's past Lion and software was becoming uncompatible (e.g. No new browsers since Lion isn't a supported OS any more.
I came across the trick to put El Capitan on it and it worked. The guy in the video said that it would need a new video card to just use a PC card as a new Mac card would be really expensive and that the only drawback would be a blank screen until it booted.
Actually, the only video problem with the video card that came with it that I've seen is only in browsers, where the cursor or the hand that clicks links has a white trail around it. It will open links but it is really annoying.
I have several PC cards but the computer just doesn't recognize them. I tried several using the native card and a new card and it shows a screen that says you need to pick which speed for different slots, but none of them actually produces any video either by itself or on a second monitor with the native one still installed.
I do not want to spend a lot of money on a new card. Is there a trick to making a PC card work or are the ones I've tried just incompatible?
Thanks.
Thanks.
